Latest post Tue, May 15 2018 2:17 PM by RalphC. 22 replies.
Page 2 of 2 (23 items) < Previous 1 2
  • Tue, Mar 13 2018 1:38 PM In reply to
    Re: Invisible project window at start, mysterious bug?
    The system specs are important to resolving problems as its normally an issue betwen the software and a software or hardware element.
    The issue here sounds very like a Graphics driver problem so knowing the card and the driver for that card is important.
  • Tue, Mar 13 2018 1:45 PM In reply to
    • Ingo Witte
    • Joined on Tue, Jan 8 2013
    • Berlin - Germany
    • Posts 10
    • Points 140
    excuse me, but is this the way Avid handles these problems? asking and run away? no solution, no suggestion?
    Human - Homo Sapiens - Biological Selfrunning Reaktor - Brain ca.1 TB length 6.4ft - weight ca. 100kg & thinkpad x1 carbon - intel core i7 4600u -... [view my complete system specs]
  • Tue, Mar 13 2018 1:59 PM In reply to
    • Posts 10,017
    • Points 215,680
    Ingo
    Spec's are important.....
    Im creating a case so community can assist you
  • Tue, Mar 13 2018 2:05 PM In reply to
    • Ingo Witte
    • Berlin - Germany
    • Posts 10
    • Points 140
    thinkpad x1 carbon, intel core i7 4600u, integrated graphic adapter, samsung ssd 256gb, uhd display 2560x1440
  • Mon, Apr 16 2018 11:42 AM In reply to
    • janko
    • Joined on Fri, Dec 22 2017
    • frankfurt am main, germany
    • Posts 7
    • Points 95
    Hi, Ingo,
    just to inform you and others with the same issue: The poblem might really be caused by the integrated graphic chip. After trying many different software based changes I finally bought and installed a pci-e dual screen graphic card and the problem no longer occured.
    So far,
    and I might aswell admit that the avid support lacks in helping out at least concerning this thread,
    best regards,
    Janko
  • Thu, Apr 19 2018 4:40 PM In reply to
    • RalphC
    • Joined on Wed, Sep 2 2015
    • Posts 1,755
    • Points 19,335
    • Avid Customer Advocate
      Avid Customer Service
      Avid Employee
    Ingo Witte:
    if you have an integrated you can set it to for MC|First, for Nvidia GPU with that machine try this.
    1. Open the Nvidia Control Panel. You can do this by right-clicking on the desktop or you can find the option within the notification area of the Taskbar.
    2. Select Manage 3D Settings under 3D Settings.
    3. Click on the Program Settings tab and select the program you want to choose a graphics card for from the drop down list. In this case MC|First
    4. Now select the 'preferred graphics processor' in the drop down list (you can see what the automatic option is listed as global setting). If you want to use the dedicated graphics card, select High-performance Nvidia processor.
  • Mon, May 14 2018 5:30 PM In reply to
    • Ingo Witte
    • Berlin - Germany
    • Posts 10
    • Points 140
    Thank you Ralph, but in my integratetd graphic adapter settings (Intel) is no avid to chose...
  • Tue, May 15 2018 2:17 PM In reply to
    • RalphC
    • Posts 1,755
    • Points 19,335
      Avid Employee
    Someone reported using Intel GPU he fixed it by deactivating several 3D options, not sure what 3D option he deactive, but I think you can find it in the GPU control panel.
    RalphC
