Latest post Fri, Dec 29 2017 5:11 AM by AndrewAction. 3 replies.
  • Thu, Dec 28 2017 9:20 PM
    partially transparent photo superimposed over video
    I'd like to create a still image in photoshop where some portions of it are transparent and superimpose that still image file over the avid video such that you can clearly see the video through the parts that are transparent in the superimposed still image.
    1. what are the steps in media composer to achieve this
    2. what file format should i export out of photoshop so as to not lose the transparent portions of the still image
    _______________________________________
    Windows 8 64bit
    intel pentium 7  64bit
    2 tarabytes internal HDD
    4 tarabytes external drive
    128GB RAM
    ASUS mother board
  • Thu, Dec 28 2017 11:16 PM In reply to
    • smrpix
    • Joined on Wed, Sep 5 2012
    • Posts 1,343
    • Points 16,510
    Re: partially transparent photo superimposed over video
    Create your image in photoshop with the proper transparency or partial transparencies as you see fit.
    Import the image into avid selecting "invert on import" under alpha channel.
    Drop your imported image media onto a higher layer than your current video layer.
    Should show through.
  • Fri, Dec 29 2017 3:03 AM In reply to
    awesome that worked perfect.  But now how can I get the photo image to last for the entire duration of the sequence?
  • Fri, Dec 29 2017 5:11 AM In reply to
    See answer in your other post.  Please refraim from double posting. Thanks
