Latest post Tue, Jun 19 2018 4:14 PM by CinéMatica. 11 replies.
Page 1 of 1 (12 items)
  • Sun, Jan 14 2018 12:27 PM
    Nitris DX driver problem
    This is weird.
    Just totally reinstalled my computer, clean Win10pro an Avid version 8.10 with Nitris DX driver 5.9.0
    When I startup Avid for the first time, it says
    "This build of the app requires a different Avid DX driver than you have installed"
    then thereis a Button with a "update" option.
    Great... of course I click on the "Update" button.
    and then it says "The system cannot find the file specified."
    Now I can click on a "Proceed" button
    And Yes I do that.
    Then this pops up "The AvidDX version you have loaded is 5.9.0.0, This version of the application works with driver versions in the range of 5.9.2.0->5.9.x.x"
    And now I can only "QUIT"
    Then i was checking for a new driver at Avid's driver download site, But the latest driver is 5.9.0 ????????
    It is NOT making any sense for me.
    Am I mising somthing or
    is Avid refusing to use Nitris DX before it has installed a driver that doesn't exist yet.
    (Maybe I was at the wrong Driver download site, if there is other)
    Please help if you see a solotion for this problem :-)
    Latest MC version, Win10pro/64bit, Xeon/E5-2650v4-2xProssesor/2,20Ghz, 12Core, 128Gb-Ram, NVIDIA M4000, Nitris DX [view my complete system specs]
  • Sun, Jan 14 2018 7:59 PM In reply to
    • CinéMatica
    • Joined on Tue, Jun 24 2014
    • Belgium | Europe
    • Posts 65
    • Points 690
    Re: Nitris DX driver problem
    Hi Frank,
    What version is your Avid Application Manager showing? I'm on a Mac and have DX Driver 8.9.4 installed. On the Windows system that I have with Media Composer | First, I see that version 8.9.1 is available.
    Hope this helps!
    Greetings,
    Ivan
    Avid Media Composer 2018.9.0.49510 | Avid Symphony Option | Avid ScriptSync 2.0 | Avid PhraseFind 2.0 | Avid Pro Tools 11.3.1.370 | Avid Application Manager... [view my complete system specs]
  • Sun, Jan 14 2018 10:28 PM In reply to
    Hi Ivan
    Thank you for taking the time to help.
    Can't find anything in Avid Application Manager, where do you find that information ?
    Ive been looking in the download center here:
    http://avid.force.com/pkb/articles/en_US/download/en379411
    but here the latest driver is 5.9, Am I looking the wrong place ?
    -Frank
  • Mon, Jan 15 2018 6:06 PM In reply to
    • CinéMatica
    • Belgium | Europe
    • Posts 65
    • Points 690
    Frank,
    In the Application Manager go to "Plug-ins". Then select "Codecs & Drivers" from the dropdown menu. There you will find the latest DX driver.
    Hope this helps!
    Greetings,
    Ivan
  • Mon, Jan 15 2018 6:36 PM In reply to
    Ok, that makes a kind of sense.
    I only see the "Codecs PE"
    I have not bought My Nitris, I have it on lone from my work to test it.
    Maybe you have to be registret as a Nitris DX owner, in you AVID Master Account, to see that driver.
    Now I have to find out how to get registretet with a Nitris DX Smile
  • Mon, Jan 15 2018 6:47 PM In reply to
    • CinéMatica
    • Belgium | Europe
    • Posts 65
    • Points 690
    Your Avid Nitris DX does not have to be registrated for this. Just login with your e-mail adress and password from your Media Composer software. Normally you then will be able to download the driver.
  • Mon, Jan 15 2018 6:50 PM In reply to
    Ok I will try that from inside the MC.
  • Mon, Jan 15 2018 6:54 PM In reply to
    • CinéMatica
    • Belgium | Europe
    • Posts 65
    • Points 690
    Normally this will work, because I just downloaded the driver. On my Windows system I have no Nitris DX and have only Media Composer | First installed.
  • Fri, May 18 2018 2:56 PM In reply to
    • Generix
    • Joined on Tue, Sep 17 2013
    • Posts 2
    • Points 30
    Hi there! i had a same issue, the support provided the answer:
    " In Media Composer 2018.5, there is an updated driver for the Nitris DX. However, this is not automatically installed when you install the editing application. The installer is located on:
    (Windows) Program Files\Avid\Utilities\DXDrivers
    There is a Win7 driver and a Win10 driver. Kindly select the one appropriate for your OS."
    It worked well for me.
    Cheers!
  • Fri, May 18 2018 3:01 PM In reply to
    • Posts 9,814
    • Points 213,060
    Yeppers Generix
    That info is in the ReadMe which usually no one reads... LOL
    AOL IM:  avidmarianna
    Skype: mariannamontague
  • Tue, Jun 19 2018 4:03 PM In reply to
    • Renn
    • Joined on Fri, Jul 6 2007
    • Posts 40
    • Points 520
    I see to be running into the same issue here, but with a Mojo DX box. I’ve upgraded to 2018.5 on my Windows 7 System SP1. Went thru the motions of installing the 64b_Win7 DX drivers in the utilities folder and I still have no connection with my mojo dx. The box was working before I did the upgrade. Any thoughts or help would be greatly appreciated. I have uninstalled and reinstalled the dx drivers with a reboot after motion.
    thanks in advance.
  • Tue, Jun 19 2018 4:14 PM In reply to
    • CinéMatica
    • Belgium | Europe
    • Posts 65
    • Points 690
    Hi, Renn
    Since a couple of versions ago you have to manually check if you want the Nitris DX or Mojo DX to be installed or not.
    During the Media Composer software installation you need to check a box on one of the first screens. If you oversee that, the Nitris or Mojo is not working.
