Latest post Fri, Mar 9 2018 6:35 PM by dannybelitz. 3 replies.
  • Tue, Jan 23 2018 3:16 AM
    Crash on startup
    Hi. I'm new to the forum, but will try to supply the info needed. I have a MacBook Pro 8,1 (13-inch, Early 2011) running High Sierra (10.13.2). Processor is 2.3 GHz Intel Core i5, 16 GB memory, Intel HD Graphics 3000 512 MB. I've installed the latest version of Media Composer | First (2018.1). When I try to start it up, it gets as far as the splash screen saying "Initializing Settings," and then I get a pop-up that says:
    "The application Avid Media Composer First has quit unexpectedly. The system and other applications have not been affected. A report has been created that you can send to Avid to help identify the problem. Please help us fix the problem by describing what happened before the crash."
    I've attempted to start it several times, always with the same result. Sometimes I've pressed the "Send to Avid" button to report the problem, and a couple times I've saved the crash log to my desktop. The crash log is mostly gibberish to me. I can post some or all of the contents if it would help.
    Any assistance you can give me to fix this so the program starts up would be appreciated. Thanks in advance.
    MacBook Pro 8,1 (13-inch, Early 2011) High Sierra (10.13.2) Processor is 2.3 GHz Intel Core i5 16 GB memory Intel HD Graphics 3000 512 MB 500 GB... [view my complete system specs]
  • Tue, Jan 23 2018 3:13 PM In reply to
    • Posts 10,202
    • Points 218,050
    Re: Crash on startup
    Christopher.....
    did you look at the specifications for MC First
    Computer: Avid-qualified Mac-based computer
    OS: Mac OS X High Sierra (10.13), Sierra (10.12), El Capitan (10.11), Yosemite (10.10)
    Processor:   Intel quad-core i7 or Intel Quad Core Xeon (with Turbo boost – 8 virtual CPU cores).  the i5 IMO is the issue.
    Memory:8 GB RAM minimum  ----  16+ GB RAM minimum required to support Media Composer | Cloud, background transcoding/render, Dynamic Media Folders, full-frame stereoscopic 3D, FrameFlex 4K workflows, Raw format AMA plug-ins, Long GOP media editing, and other high- performance workflows
    RAM listed is what Avid tested as part of the qualification process. Adding more memory is supported as long as it adheres to the manufacturer’s recommendation
    Graphics card1:NVIDIA GeForce family, Intel HD4000/5000, ATI Radeon or AMD Radeon Pro o Graphics and driver must be supported by Apple
     Internal hard driveMinimum 500 GB 7200 rpm SATA drive or 256 GB SSD
  • Wed, Jan 24 2018 1:28 AM In reply to
    I think you're right. I missed the processor spec. Thanks for your help--sorry about the rookie mistake. Embarrassed
  • Fri, Mar 9 2018 6:35 PM In reply to
    Is there any way to downgrade? Is there any version that runs on the i5 processor? How did you fix the issue?
    Many thanks!
    Gabriel
