Latest post Fri, Jan 26 2018 4:49 PM by Andy Christen. 2 replies.
  • Thu, Jan 25 2018 10:24 AM
    Can someone confirm? Bins open up incorrectly (MC 2018.1)
    Hi, I have a 3 monitor setup and I resize the Media Composer application to only 2 monitors.
    When I open a existing bin, the bin opens in the top left corner and I'm not able anymore to move it to a different position because the top of the bin is not showing up. This occurs since version 8.10 and only when I resize MC. («New Bin» open up correctly.)
    Nvidia Quadro M4000 (driver: 385.08, resolution: 3 x 1920x1200)
    Does anyone of you have the same problem?
    HP Z-8 | Xeon 2 x gold 5118 @ 2.3 GHz (12 cores)| 96 GB RAM | NVIDIA Quadro P4000 | Win 10 Pro 64 Bit | Blackmagic DNxIQ | MC 12.1 | Symphony Option *... [view my complete system specs]
    Andy Christen
    Filed under: , , , , ,
  • Fri, Jan 26 2018 11:57 AM In reply to
    • Joachim Claus
    • Seeheim-Jugenheim, Germany
    • Posts 916
    • Points 11,725
    Re: Can someone confirm? Bins open up incorrectly (MC 2018.1)
    This has been discussed in the MC beta forum. It is an issue with exising bins being opened when monitor configuration or scaling has changed.
    There have been reported two solutions:
    1. right click in the bin and select "close", and then reopen the bin. It should now show the top line of the bin, so that you can move it to the desired position.
    2. left click on the left edge of the bin and shrink the bin should also re-display the top of the bin.
    There is still another issue with bin positions. When running in a dual monitor configuration with UHD monitors, the bin postion is not stored correctly when the bin was placed on the right monitor. It looks like MC currentlly cannot handle horizontal position larger than 3840/4096. The bin re-opens tzhen at the right end of the first monitor. This bug is currently handled by Avid engineering. Good luck, Joachim
    Joachim Claus
  • Fri, Jan 26 2018 4:49 PM In reply to
    Dear Joachim, thanks for your fast reply – I really appreciate that.
    Und liebe Grüsse aus der Schweiz.
    Andy
    Andy Christen
