Latest post Tue, May 29 2018 2:12 PM by Marianna. 5 replies.
Page 1 of 1 (6 items)
  • Wed, Feb 7 2018 3:20 PM
    • Obscure
    • Joined on Tue, Jan 23 2018
    • Posts 24
    • Points 340
    8.4 to 8.9.4/8.10 Project Upgrade Issue - Thin Raster Material Squeezed
    We have a pre-edit that was started in v8.4. We are hoping to upgrade to v8.9 or v8.10 for the main edit.
    All of our edit proxies are XDCAM 17.5 MXF, which is a thin-raster codec (1440x1080). When I open the project in v8.9 or v8.10, all of the sequences look fine and everything is formatted correctly.
    As soon as I match frame (or refresh sequence), the source material is 'squeezed' towards the left hand of frame, leaving a large black bar at the right hand of frame.
    I have checked in the frame flex window (via source settings) and this material is being interpreted by the Avid as 1920x1080 16:9. However, the material is the wrong shape in both of the frame flex viewers - I can supply a screen-grab if required.
    Is this a known bug and if so, is there a workaround?
    Thanks in advance!
  • Wed, Feb 7 2018 3:50 PM In reply to
    • Posts 10,282
    • Points 219,150
    Re: 8.4 to 8.9.4/8.10 Project Upgrade Issue - Thin Raster Material Squeezed
    Obscure
    Can you email me this info and send a screengrab.  email below
  • Wed, Feb 7 2018 4:08 PM In reply to
    • Obscure
    • Posts 24
    • Points 340
    Thanks - I have sent you an e-mail!
  • Wed, Feb 7 2018 4:10 PM In reply to
    • Posts 10,282
    • Points 219,150
    Perfect - checking now
  • Mon, May 28 2018 1:14 AM In reply to
    Dear Marianna,
    I have exactly the same problem.
    Although I haven't updated Avid, but macOS.
    Were you able to resolve the squeeze issue?
    thanks in advance,
    Patrick
  • Tue, May 29 2018 2:12 PM In reply to
    • Posts 10,282
    • Points 219,150
    Patrick
    It was resolved in 2018.2 ....
