Latest post Tue, May 29 2018 10:45 PM by Forever1337. 34 replies.
Page 1 of 3 (35 items) 1 2 3 Next >
  • Thu, Feb 8 2018 3:01 AM
    • Bassnote
    • Joined on Thu, Feb 8 2018
    • Posts 6
    • Points 80
    None of your installed products can be licensed via application manager
    Hi everyone,
    I just downloaded Media composer First last night. Yes the free one Yes. I tried to launch it tonight to learn this program. FAIL!
    The application manager under apps launches the program then application manager kicks down to License. The Composer pops up a window saying Login required (Did that), Please quit and login to Avid Application Manager and relaunch Media Composer First.
    Does this have something to do with iLok License Manager, I notice this icon on my desktop after the download. Not sure what this thing is!!
    Thank You for your responses
  • Thu, Feb 8 2018 1:53 PM In reply to
    • RalphC
    • Joined on Wed, Sep 2 2015
    • Posts 1,791
    • Points 19,765
    • Avid Customer Advocate
      Avid Customer Service
      Avid Employee
    Re: None of your installed products can be licensed via application manager
    Hi Bassnote,
        Please do this in order:
    • Launch AppMan and sign in
    • Select Apps tab
    • then click "Open"
     This should launch the main application, report back.
    RalphC
  • Fri, Feb 9 2018 5:20 PM In reply to
    • UvaSEP
    • Joined on Fri, Feb 9 2018
    • Posts 2
    • Points 20
    I'm having the same problems as Bassnote and followed the suggestion of RalphC; no change.
  • Fri, Feb 9 2018 9:37 PM In reply to
    • RalphC
    • Posts 1,791
    • Points 19,765
      Avid Employee
    Hi UvaSEP,
       Can you confirm the following:
    1.  You are log in on the AppMan
    2.  You have "Open" button in the Apps tabs
    3.  AppMan is not continuously  in sync status
    4.  Firewall is disable
    5.  Data Colletion is check
    RalphC
  • Sat, Feb 10 2018 10:01 PM In reply to
    • UvaSEP
    • Posts 2
    • Points 20
    Thanks RalphC!  Figured it out, it was a Firewall issue
  • Sun, Feb 11 2018 5:31 AM In reply to
    • Bassnote
    • Posts 6
    • Points 80
    Hi, sorry for the delayed response. I was having major issues with Win 8.1. I decided to remove all the crap bloatware from win 8.1 to speed up this computer. Then I realized in my work, that Win 8.1 is all crap. So we got rid of the Wincrap. I loaded Win 10 (a little more stable). So in doing this Media Composer First went with it.
    So after a fresh install, I reloaded Media Composer First in Win 10. No change, in AppMan there was no "Open" App. Just the license tab kept popping up. This is the Program I really wanted to learn, but too many problems, so I scrubbed the idea. I wish it came in Linux as that is what I use daily.
    I have Openshot and 1 other, but they are not the program Media Composer is. I want to do educational videos for kiddos, maybe I will keep trying, but I have some videos I have to get out. So this project will have to be on hold, unless someone has words of wisdom to reach my goal of Media Composer (First)!
    So what would cause it to not be recognizes in AppMan? A firewall?
  • Sun, Feb 11 2018 3:46 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,526
    • Points 45,350
    If you have a firewall and/or antivirus software running, try disabling them and then running the app. manager (if your system is directly connected to the internet and not through a router, then don't disable anything; instead figure out the settings to allow appman through the firewall). If appman works with the firewall disabled, then that's your issue.
    Dave S.
  • Mon, Feb 12 2018 4:28 AM In reply to
    • Bassnote
    • Posts 6
    • Points 80
    Thank You, I will have to download the program again. Try what your suggesting and see if I can use this program I'm very interested in.
    I think through win10 and my cable router I can just click to let it communicate
  • Mon, Feb 12 2018 7:08 PM In reply to
    • Posts 10,079
    • Points 216,475
    Dave is spot on with his suggestions.  Let us know how it works out.
  • Mon, Feb 12 2018 7:49 PM In reply to
    • Matthew Clulow
    • Joined on Mon, Feb 12 2018
    • North of Toronto Ontario
    • Posts 25
    • Points 255
    Having a similar set of problems. I thought I had allowed this pass through the firewall becasue it asked to veryfy and gave me the yes/no option. Going to check this through. Windows Defender and Norton 360 are both running.
    I did start the program through app-manager.
    It launched an then freezes at this screen...the mouse click dings wherever I try. Can't do anything, can't minimise or close. Have to use task manager to dump it.
    On one attempt I got the mouse highlight over the center of the screen as if there was a hot-link there, but nothing was displayed. Grahpics card issue?  System specs are listed in my in profile
    Windows 10 Pro Version: 1709 OS Build 16299.192INtel Core(TM) i5-2400 CPU @3.10Ghz 310 GHz8GB Ram - 7.88 usable64 bit x64 based processorDell Optiplex... [view my complete system specs]
    Matthew Clulow
  • Tue, Feb 20 2018 3:30 AM In reply to
    • Bassnote
    • Posts 6
    • Points 80
    I reloaded the Media First and now in Login I'am getting "Unknown error". I have no antivirus loaded yet, I turned off the Windows Firewall. So Im beginning to believe Media First doesn't like my laptop.
    I did get Media First loaded into a desktop recently and it  signed in and worked. So my question is, am I allowed to have Media First on two different computers? The Desktop I loaded, was to see if I could and it worked flawlessly. My laptop, not so much.
    Laptop is a Samsung with an A8 processor, 8 gigs of ram, intergrated video. I know it's not strong, but I wanted to be mobile with the Media First.
  • Thu, Feb 22 2018 1:40 PM In reply to
    • RalphC
    • Posts 1,791
    • Points 19,765
      Avid Employee
    Bassnote:
     Yes, you can install MC|First on two different machine. Often you will get an "Unknown error" if you sign in while AppManHelper is still trying to sync. Make sure there's no background task processing when you log in.
  • Tue, Feb 27 2018 3:53 PM In reply to
    • BobVEdit
    • Joined on Thu, Jan 25 2018
    • Posts 9
    • Points 125
    I have a avid ap manager helper that is running in the background according to the Task Manager. It keeps erasing my password and I cannot log on.  Everything was fine about a month ago after first installation but since I went back to a small project it will not let me in. I have deleted and reinstalled the program to no avail. I tried to get on with the firewall down...nope. Is this in continous sync??
    I really need some help please. Thanks.
  • Tue, Feb 27 2018 3:58 PM In reply to
    • Posts 10,079
    • Points 216,475
    Bob
    Are you using MC | First?  which version?  What version is your AppMan?
  • Tue, Feb 27 2018 4:03 PM In reply to
    • BobVEdit
    • Posts 9
    • Points 125
    Thanks for the help
    App man 2018.1
    MC/F 2018.2
