Latest post Mon, Feb 19 2018 10:34 PM by Anderella. 12 replies.
Page 1 of 1 (13 items)
  • Mon, Feb 12 2018 12:16 AM
    • Anderella
    • Joined on Mon, Feb 12 2018
    • Posts 7
    • Points 85
    MC crashes on startup during Initializing Audio Effects
    after updating my system from MC Version 8.7.0 to 8.9.3 Avid Media Composer crashes on startup during initializing audio effects.
    My OSX: 10.10.5
    For crosscheck I went back via carboncopycloner to my last running system, and updated my system to osx 10.11.6.
    Afterwards I updated Avid MC to Version 8.9.3 - same problem, crash on startup.
    Help very much appreciated, crash Log and screenshot enclosed....
  • Mon, Feb 12 2018 7:06 PM In reply to
    • Posts 9,508
    • Points 209,170
    Re: MC crashes on startup during Initializing Audio Effects
    Hi there
    You definately have a plug in that doesnt like the new version of the new OS.
    Serach for your plug in folder and drag it to the desktop.  launch and I suspect it will work.  Now you need to remove them a few at a time to find out which one is the culprit.
    AOL IM:  avidmarianna
    Skype: mariannamontague
  • Mon, Feb 12 2018 10:11 PM In reply to
    • Anderella
    • Posts 7
    • Points 85
    Thank you very much for your input, I will try....... not quite sure, where to fnd the plugins.....
    But what's strange:
    The error occurs after updating the MC Version, not the OS. (I testwise updated to OS 10.11 afterwards and for cross-check (after restoring my system via carboncopycloner) before updating the MC version, to focus on the troublemaker.... and it's the avid update :(
  • Mon, Feb 12 2018 10:41 PM In reply to
    • Posts 9,508
    • Points 209,170
    Andrella
    It could be that the version of MC First required a new OS and or that new version of MC First wasnt competible with the plug in that is causing the issue.
    Mac or PC?
    marianna
  • Mon, Feb 12 2018 10:56 PM In reply to
    • Anderella
    • Posts 7
    • Points 85
    Hi Marianna,
    thanks for your help, as written, I'm on OSX and tried both 10.10 and 10.11 (El Capitan)
    No way to "read out" the Crash Log ?
  • Mon, Feb 12 2018 10:59 PM In reply to
    • Posts 9,508
    • Points 209,170
    Wait - it this Media Composer or Media Composer | First we re talking about here?
    M
  • Mon, Feb 12 2018 11:15 PM In reply to
    • Anderella
    • Posts 7
    • Points 85
    Avid Media Composer, Version 8.9.3, Hardware Dongle, permanent license
  • Mon, Feb 12 2018 11:40 PM In reply to
    • Posts 9,508
    • Points 209,170
    Moved to the Media Composer Mac forum.
    Go to: Mcintosh HD and search for AVX PLuig In folder.
    Drag to the Desktop
    Launch MC
    If it launches which I bet it will
    Duplicate the plug in folder - empty it.
    drag the content of the original Plug in folder into the copy.
    then a few at a time, out them in the original folder in the location where the AVX folder orignally was.
    see which series of plugs causes this
  • Mon, Feb 12 2018 11:51 PM In reply to
    • Anderella
    • Posts 7
    • Points 85
    Sorry for posting in the wrong forum....
    Not at my mac right now, I check out tomorrow and get back to you, thanks
  • Tue, Feb 13 2018 3:38 PM In reply to
    The folder is in /Library/Application Support/Avid.
  • Sat, Feb 17 2018 9:28 PM In reply to
    • Anderella
    • Posts 7
    • Points 85
    Update:
    Had been busy..... sorry for the delay.
    This is strange!
    I moved all audio plugins from folder /Library/Application Support/Avid/Audio/Plug-Ins
    to a new desktop folder.
    MC started without error.
    Afterwards I moved back plugin by plugin and tried to launch MC.
    After some trial and errors I found the "bad guy" - Normalize-Gain.aaxplugin
    wirh all other plugins back in the avid subfolder and MC started like it should.
    For cross-check I afterwards also put the "bad-guy" back in the plug-ins folder - and this is really weird, now MC started without any problem...... !
    Any ideas on this?
  • Mon, Feb 19 2018 3:51 PM In reply to
    It might have been a permissions issue? Perhaps copying it back and forth solved something.
    Anyway, enjoy the working system!
  • Mon, Feb 19 2018 10:34 PM In reply to
    • Anderella
    • Posts 7
    • Points 85
    Thanks for all your help....
    I'm happy it works now :)
    Regards from austria.....
