Latest post Fri, Mar 9 2018 5:40 PM by Marianna. 4 replies.
  • Wed, Feb 21 2018 7:55 PM
    • DonE
    • Joined on Tue, Aug 18 2009
    • California, USA
    • Posts 78
    • Points 935
    MC 2018.2 AAF Closed Caption file Import fails. scc Import fails
    I started with a clean install of OS X 10.12.0, then upgraded it to 10.12.6, then installed MC 2018.2. The Data Track only AAF Import would not work. "Some of the embedded media failed to import". From the console: Error importing media for '10ThingScreener_24.mxf'. Error: 'SYS_ERROR'. This is the third time in my memory that this import has been broken after a MC update. The last time it was broken in 8.8.2 (.3 & .4) and fixed in 8.8.5.
    http://community.avid.com/forums/p/180804/842623.aspx#842623
    I also found that scc file import would not work at all for me. Console: AncData Import: Error. Unable to decode "INCRHULK2008_EDIT-FFM_CC_23_ENG(rev2).scc"Exception:
    @ Wed Feb 21 07:55:06 2018
     18.2.0.48210.0
    • Exception: SYS_ERROR
    First I did an uninstall / reinstall of 2018.2 but had the same problems. Then I uninstalled 2018.2 and installed 2018.1. The same files imported with no problems.
    Has anyone else tried these Closed Caption imports?
    Don
    1x AMC/Sy 8.2.11-Win7 Pro 64-HP z800-dual 6core-24GB-Quadro FX 4800-Nitris DX QT775 NV340.84** 3x AMC/Sy 8.2.11-Win7 Pro 64-HP xw8600-8GB-Quadro FX 3700... [view my complete system specs]
  • Fri, Feb 23 2018 4:59 PM In reply to
    • Posts 10,079
    • Points 216,495
    Re: MC 2018.2 AAF Closed Caption file Import fails. scc Import fails
    DonE
    Let me check it out for you...  I created a case and have support looking at this.  Case # 03411101
    Stand by
  • Fri, Feb 23 2018 7:13 PM In reply to
    • DonE
    • California, USA
    • Posts 78
    • Points 935
    Thanks Marianna.
    Avid Customer Care has reproduced this and it will be logged as a Bug.
  • Fri, Mar 9 2018 5:29 PM In reply to
    • DonE
    • California, USA
    • Posts 78
    • Points 935
    This issue took an interesting turn. The Avid tech who reproduced this contacted me and said when he submitted this as a bug, engineering told him he was using a beta 2018.2 and he should download and install from the Avid download site. After doing that, both aaf and scc imported correctly. He asked me to re-download and test. I downloaded a 2nd copy from the download site that was the same size and same md5 checksum as my original download. I uninstalled 2018.1, including a couple of manual additions to the uninstall that he asked me to do, and re-installed the new copy of 2018.2. Both aaf and scc imports work fine for me now. I have since tested the Windows side of 2018.2 and it works fine also. Go figure...
    Don
  • Fri, Mar 9 2018 5:40 PM In reply to
    • Posts 10,079
    • Points 216,495
    DonE
    Weird as we did release 2018.2 and then pulled it back from the DL right away. Might you have gotten it there?
    Glad all is well and I will be checking the download site and what you would have received from Appman to verify that it is correct now.
