Latest post Thu, Dec 6 2018 8:52 PM by David Lachance. 9 replies.
Page 1 of 1 (10 items)
  • Fri, Feb 23 2018 12:04 AM
    • Rob
    • Joined on Wed, Sep 12 2007
    • Australia, Victoria
    • Posts 129
    • Points 1,690
    MC start-up hangs on 'Initializing Avid Media Access Volume Manager
    Realise this problem has cropped up a few years back.
    https://community.avid.com/forums/t/80248.aspx?PageIndex=4
    It takes 4 minutes wait for Avid 2018.2 to wakeup from this issue.
    Apart from disconnecting the network which does seem to free this system up to go. Is there any settings or known fix for this.
    It didn't happen in the earlier systems MC2018.1. Any help would be appeciated.
    Rob
    PC - CPU: Intel Xeon i7 7700k 4.2GHz: RAM: Corsair 64gb: MomBoard: Asus Strix 270-H: GPU: ASUS Strix GTX-1070 Geforce: Nvidia v390.77 Media Composer 2018... [view my complete system specs]
  • Fri, Feb 23 2018 4:31 PM In reply to
    • Posts 10,018
    • Points 215,685
    Re: MC start-up hangs on 'Initializing Avid Media Access Volume Manager
    Rob
    Are you able to clear the cache in the appman and does that make a difference?
    marianna
  • Sat, Feb 24 2018 12:52 AM In reply to
    • Rob
    • Posts 129
    • Points 1,690
    Thanks Marianna for your response.
    I haven't cleared the cache in the App at all. Previously I completey removed the cache manually from the avid file in the c' drive, MC, 'AMA management folder'. Initially that didn't change anything and the problem still existed.
    This morning i opened the program from a complete shutdown with my NAS off (but ethernet connected) and without any other changes and AVID system booted up without any delay.
    I am not sure if this has,
    a. Resolved the issue, by the clearing of the AMA Management cache manually previously, then by starting the PC from a shutdown; or
    b. Having the NAS off from startup has stopped AVID from accessing any volume files via ethernet port.
    Does the AppManager do the same as removing the AMA management cache files?
    At the moment I will monitor the result and report back.
  • Sun, Feb 25 2018 9:43 PM In reply to
    • Rob
    • Posts 129
    • Points 1,690
    So the latest update Is:
    Having the NAS on and ethernet connected whilst booting up Avid creates this issue with the volume manager.
    So the only change I did to my system was to to update to AVID 2018.2 from version 2018.1
  • Mon, Feb 26 2018 3:40 AM In reply to
    • Rob
    • Posts 129
    • Points 1,690
    Update: Clearing the Application Manger did not reslove the issue either.
  • Mon, Feb 26 2018 5:58 PM In reply to
    • Posts 10,018
    • Points 215,685
    One thing Rob
    AppMan 2018.2 was just released and fixes a bug relating to networks
    MCCET-2291. When Media Composer and Application Manager were running, WIFI speed dropped significantly.
    Can you try to update to that..... so MC 2018.2 and AppMan 2018.2 are in sync.
  • Mon, Feb 26 2018 9:09 PM In reply to
    • Rob
    • Posts 129
    • Points 1,690
    Thanks again Marianna
    I have had AppMan and Avid up to date. Re-synced but problem exits.
    The issue is hard wired network and not wifi. As I don't use wifi for networking.
    I can definately stop the issue by removing the network cable or leaving the network cable in and turning off the NAS. Avid boots up within seconds.  Otherwise it takes almost 4 minutes waiting before it boots in.
  • Mon, Feb 26 2018 9:22 PM In reply to
    • Posts 10,018
    • Points 215,685
    Rob
    I am going to have engineering take a look see.  Can you email me or message me thru here your email address and system ID
  • Mon, Feb 26 2018 9:34 PM In reply to
    • Rob
    • Posts 129
    • Points 1,690
    Have emailed you. Rob
  • Thu, Dec 6 2018 8:52 PM In reply to
    • David Lachance
    • Joined on Fri, Oct 29 2010
    • Quebec City, Qc
    • Posts 2
    • Points 10
    Hi Folks,
    I got this issue with MC2018.7, Appman 2018.8. Is there a fix, i'm on Nexis so disconnecting the network is not an option.
    Best regards,
    David
    MediaComposer 2018.7 Dell 7910, Nitris DX [view my complete system specs]
