Latest post Tue, Feb 27 2018 6:15 PM by Marianna. 6 replies.
Page 1 of 1 (7 items)
  • Tue, Feb 27 2018 12:14 PM
    • ljbailey88
    • Joined on Tue, Feb 27 2018
    • Posts 3
    • Points 55
    "Exception: Failed to get the sample position from the AMA plugin"
    Hi All
    Any help would be greatly appreciated!
    I have recently installed Avid First on a new computer to continue with an old project. Whilst I have been able to open the project and relink the media the project will not play back or let me edit in anyway.  Error messgae "Exception: Failed to get the sample position from the AMA plugin" comes up every time I try to play the sequence.
    I am very new to avid so would massively appreciate any help or advice!
    Thank you in advance!
  • Tue, Feb 27 2018 2:43 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,569
    • Points 45,830
    Re: "Exception: Failed to get the sample position from the AMA plugin"
    Welcome to the forums. For starters, we need a bit of information. What kind of computer (Mac or PC) and what are the spec's (CPU, memory, disk layout, etc.) What OS are you running and which version of MCF? And on which version of MCF did you start the old project?
    Dave S.
  • Tue, Feb 27 2018 2:44 PM In reply to
    • Posts 10,219
    • Points 218,265
    First check your drive.  Make sure it is funcitoning proeprly.    The error usually is assoctaed with a corrupt clip(s) so try and determine where it is playing when it crashes and see if you can replace that media.
    Would need to know more about the old project - what formats and media types are being used.  I see this error alot with Resolve.
  • Tue, Feb 27 2018 3:31 PM In reply to
    • ljbailey88
    • Posts 3
    • Points 55
    Thank you very much for your response.
    The computer I have moved to is a PC with Intel® Core™ i7-7500U Processor, RAM: 8 GB / Storage: 256 GB SSD. The project was originally started on a PC but of a higher spec.
    I am  using version 2018.2 and I believe the old project was also using 2018.2 (unfortunately my old computer is currently away for repair so i can't double check)
    Thank you!
  • Tue, Feb 27 2018 3:44 PM In reply to
    • Posts 10,219
    • Points 218,265
    Does it always crash at the same plce when playing back the timeline?  If so, remove that clip and see if it plays ok.
  • Tue, Feb 27 2018 4:00 PM In reply to
    • ljbailey88
    • Posts 3
    • Points 55
    Unfortunately it's not one particular clip it is the whole sequence and all other sequences within the project.
    Every time I try to play a clip or part of the sequence I get the error message.
  • Tue, Feb 27 2018 6:15 PM In reply to
    • Posts 10,219
    • Points 218,265
    Any non-alphanumeric characters in the file path?  Like / or :
    And where did the Old project sequence come from?  Media Composer and if so what version?  FCP???  Premiere????
