Latest post Wed, Mar 7 2018 12:22 AM by Vadym. 1 replies.
Page 1 of 1 (2 items)
  • Tue, Mar 6 2018 10:28 PM
    Unexpected error moving asset
    Normal 0 false false false EN-US X-NONE X-NONE MicrosoftInternetExplorer4
    /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;}
    When attempting to move an asset in interplay via the ipws command move I am getting the following error. The same command works fine on my demo system. Can somebody point me at what could be the cause of it? We have verified the paths exist and can copy / move files there manually in interplay access.
    its not invalid paths because that would be throwing a path not found error. I know that from when i had the wrong path.
    <soap:Envelope xmlns:soap="http://schemas.xmlsoap.org/soap/envelope/">
                    <soap:Body>
                                    <soap:Fault>
                                                    <faultcode>soap:Server</faultcode>
                                                    <faultstring>An unexpected error occurred moving asset interplay://RAINWG/Catalogs/To_Transfer/060a2b340101010101010f0013-000000-5a983591df390065-060e2b347f7f-2a80 to location interplay://RAINWG/Catalogs/To_Transfer/Failed/.</faultstring>
                                                    <detail>
        <AssetsFaultType Code="OTHER_ERROR" xmlns="http://avid.com/interplay/ws/assets/types">
        <Message>An unexpected error occurred moving asset interplay://RAINWG/Catalogs/To_Transfer/060a2b340101010101010f0013-000000-5a983591df390065-060e2b347f7f-2a80 to location interplay://RAINWG/Catalogs/To_Transfer/Failed/.</Message>
        <Details>An unexpected error occurred moving asset interplay://RAINWG/Catalogs/To_Transfer/060a2b340101010101010f0013-000000-5a983591df390065-060e2b347f7f-2a80 to location interplay://RAINWG/Catalogs/To_Transfer/Failed/.</Details>
        </AssetsFaultType>
                                                    </detail>
                                    </soap:Fault>
                    </soap:Body>
    </soap:Envelope>
  • Wed, Mar 7 2018 12:22 AM In reply to
    • Vadym
    • Joined on Thu, Apr 17 2014
    • Posts 214
    • Points 2,635
    • Avid Developer Moderator
      Avid Employee
    Re: Unexpected error moving asset
    Hi Jeff,
    you can try to move the asset in question using Interplay Access and see if that works to verify that this is not an issue with this specific asset.
    Also you can retry move and see if it works and case the asset in question was locked by another request
