Latest post Thu, Mar 8 2018 12:24 AM by askdkiasdfals. 2 replies.
  • Wed, Mar 7 2018 11:06 PM
    Exception when linking MP4/H.264 file
    I'm using Media Composer First 2018.2 on Windows.
    I can import (and transcode) an MP4/H.264 file, but doing 'link' will show 'An error has occured' - 'Assertion failed: normalCaching || smallCaching - 'File ..\..\src\filesys\CoreWilFileLocator.c, Line: 1426
  • Wed, Mar 7 2018 11:57 PM In reply to
    • Posts 10,156
    • Points 217,355
    Re: Exception when linking MP4/H.264 file
    does this happen with all the clips ?  can you link one and one and see if it occurs?
    Open the Source Browser window, select the Link button.  Then select 1 or 2  clips you want and drag and drop them to the bin. (Ctrl+click or Shift+click to select multiple files.)
    what happens?
    If it works then one of the files in thw group you originally linked is suspect/corrupt
  • Thu, Mar 8 2018 12:24 AM In reply to
    I tested with multiple MP4/H.264 files and I was able to find one that would get into the bin via 'link'.
    The other files may have encoding/muxing differences but I wouldn't say they are corrupt, as they play back in Quicktime properly and can be transcoded by Media Composer.
