Latest post Mon, Oct 8 2018 12:35 PM by Isaac T.. 4 replies.
  • Thu, Mar 8 2018 9:09 AM
    • Luke Byrne
    • Joined on Wed, Mar 7 2018
    • Dublin, Ireland
    • Posts 1
    • Points 25
    Transcode issue - NEMFileWriter has detected upstream pipe stall
    Hi Everyone, first time posting.
    I'm in the middle of ingesting & transcoding a bunch of Rushes for a show and keep on getting stopped by this error: (Exception: NEMFileWriter::ExecuteInternal TIMEOUT -  NEMFileWriter has detected upstream pipe stall...) and occasonisly this error in the source montior aswel (AMA Producer Task::Execute AMA Plug-in Unable to Provide Sample)
    Rushes in question are .MOV and H264 codec. Default AMA link was AvidGeneric and changed this to Quicktime and still no luck. Some suggestions on the forum was to try background transcode as something to do with the ISIS server not liking the amount of data it was receiving. Working on certain clips and not on others, have tried to subclip long clips and do trial and error but even with this I'm getting the Ama Producer Task error.
    Any advice/tips greatily appreciated.
    Luke
    Media Composer 2018.2.0 | MacBook Pro i7 2.7gHz | 16GB Ram | 500GB SSD | Intel Iris Graphics 6100 1536 MB | mac OS Sierra | [view my complete system specs]
    Filed under: ,
  • Mon, Mar 12 2018 3:05 PM In reply to
    • Posts 10,227
    • Points 218,330
    Re: Transcode issue - NEMFileWriter has detected upstream pipe stall
    Hello Luke
    Welcome to the forums....
    How many files are in your MXF folder?
    http://avid.force.com/pkb/articles/en_US/error_message/Exception-AMAProducerTask-Execute-AMA-Plug-In-Unable-to-Provide-Sample
    Let us know...
    marianna
  • Fri, Oct 5 2018 3:39 PM In reply to
    • nigelad
    • London UK
    • Posts 528
    • Points 6,120
      Avid Certified User
    Hi Mariana
    I just had the "Exception-AMAProducerTask-Execute-AMA-Plug-In-Unable-to-Provide-Sample" repeatedly while trying to demonstrate the trim tool in MC 18.4.  I was working with the Avid supplied "Rock Climber" linked files.
    Any advice appreciated.
    Nigel
    ISIS 5500, MC 18.4 & PT 18.4 on Mac OS with BMD Mini-Monitors, an UltraStudio 4K and AJA T-taps. [view my complete system specs]
  • Fri, Oct 5 2018 6:03 PM In reply to
    • Posts 10,227
    • Points 218,330
    Nigel
    This almost always caused by Perian being installed on the system.
    Specifically on MAC
    Uninstall Perian immediately.
    Also be aware Perian has several additional files that come when installed.
    Make sure you are able to uninstall all of them.
  • Mon, Oct 8 2018 12:35 PM In reply to
    • Isaac T.
    • Joined on Mon, Jan 9 2006
    • New York / Knoxville, TN
    • Posts 747
    • Points 8,810
    @Luke Byrne:
    Luke Byrne :
    I've seen this error when transcoding directly from a network share (e.g. ISIS).
    https://community.avid.com/forums/p/130389/745180.aspx#745180
    If possible:
    1. Copy the media to a fast local drive on your workstation.
    2. Transcode on that drive, then...
    3. Copy the transcoded media back up to the server.
    Mid-2010 Mac Pro • 2018 MacBook Pro [view my complete system specs]
    isaact.co | Twitter | Instagram | Vimeo
    Writer: The Frame.io WORKFLOW Guide - http://workflow.frame.io/
    Post Workflow Consultant - https://isaact.co/
