Latest post Thu, Mar 29 2018 10:08 PM by jef. 11 replies.
Page 1 of 1 (12 items)
  • Fri, Mar 9 2018 8:42 AM
    • reckoner
    • Joined on Sun, Sep 26 2010
    • Auckland, New Zealand
    • Posts 159
    • Points 2,270
    Quality loss on export
    Hi all,
    I'm having an issue with video quality being noticably reduced on export.
    This is my workflow:
    Sony XAVC 4K files > AMA into Avid MC 2018.2 in a 1080p project > Finish edit and do a video mixdown DNxHD 185X > Export same as source.
    On comparing the resulting Qucktime file with the original clips from the camera, noticable detail has been lost and the image is a lot softer. I realise I'm going from 4K to 1080p, but the image should still be nice and sharp. Even when viewed on a 1080p monitor, it's soft.
    I'm not sure if this is a new issue, or something I've not noticed before - I've used MC for years. But it doesn't make much sense as the mixdown and same as source export should be vitually lossless.
    If anyone could shed any light on this issue, it'd be really appreciated!
    Thanks very much.
    Media Composer 2018.2 | i7 4390K | 32GB RAM | Quadro K620 | 256GB SSD | 8TB RAID 0 media drive [view my complete system specs]
  • Fri, Mar 9 2018 11:08 AM In reply to
    Re: Quality loss on export
    Well it should look 4x softer as there is only a quarter of the resolution.
    Are you able to see the timeline output on a HD monitor? how does that look before the export?
    And as a comparrison have you tried taking one of the 4K (well its UHD not 4K I suspect) into squeeze or similar and transcoding to DNx185x as a comparrison?
  • Fri, Mar 9 2018 12:53 PM In reply to
    Pat Horridge:
    +1
    Desktop PC
    3 Heads Digital Films
  • Sun, Mar 11 2018 3:06 AM In reply to
    • reckoner
    • Posts 159
    • Points 2,270
    Before the export, the clips look great.
    As a comparison, I've exported the same clips same as source from a UHD project, and then converted to a 1920x1080 file using Adobe Media Encoder. The resulting video is much higher quality than if I'd exported the same clip from a 1080p project. My only conclusion is that Avid doesn't do a great job of downscaling from 4K/UHD to 1080p.
    This is unfortunate with the obvious benefits of working with UHD footage in a 1080p project.
  • Sun, Mar 11 2018 10:04 AM In reply to
    reckoner:
    Haven't seen that, however I always export SAS and do the transcode at an encoder.
    Desktop PC
  • Sun, Mar 11 2018 11:52 AM In reply to
    • reckoner
    • Posts 159
    • Points 2,270
    Yes so do I. But I'm using AMA to bring 4K files into a 1080P project - then mixing down before exporting SAS. So the issue must lie in the mixdown process.
  • Sun, Mar 11 2018 2:12 PM In reply to
    • jef
    • Joined on Sun, Feb 26 2006
    • Maryland
    • Posts 3,375
    • Points 40,765
    reckoner:
    Can you tell us how you are doing this comparison?  Are you bringing the export back into Avid, stacking it above the final mixdown and comparing that way?
    Jef
    Jef Huey
  • Sun, Mar 11 2018 3:00 PM In reply to
    • smrpix
    • Joined on Wed, Sep 5 2012
    • Posts 1,361
    • Points 16,770
    reckoner:
    Why not flip your project to 4K before doing the mixdown, export to QT Reference, then encode to 1080 with AME?
  • Sun, Mar 11 2018 10:34 PM In reply to
    • reckoner
    • Posts 159
    • Points 2,270
    I didn't think of that - will give it a try. Thanks!
  • Thu, Mar 15 2018 10:34 AM In reply to
    • fkurz
    • Joined on Wed, Jan 23 2008
    • Posts 31
    • Points 380
    in my experience the downconversion of 4k/UHD to HD in Avid MC is noticeable softer than in other apps like Resolve etc.. Avid should optimise that scaling algorithm!
    Regards
    Flo
    Avid MC 2018.2 symphony option HP Z820 Win 7 64Bit, SP 1 Mojo-DX Interface [view my complete system specs]
  • Thu, Mar 29 2018 9:20 AM In reply to
    • reckoner
    • Posts 159
    • Points 2,270
    Thanks for the feedback.
    I've now changed my workflow to a 4K/UHD project > output same as source > convert to 1080p with Adobe Media Encoder. The result is a MUCH sharper image.
    This is unfortunate as it just makes for larger file sizes, longer output times and loses the ability to crop into the 4K/UHD image in a full HD project.
  • Thu, Mar 29 2018 10:08 PM In reply to
    • jef
    • Maryland
    • Posts 3,375
    • Points 40,765
    reckoner:
    The quality of any scaling can be effected by the filter algorithm being used.  If you look in Blackmagic Fusion (a compositing tool, not an editing tool for sure) there are at least 11 filter types to choose from.  All with various best uses.
    In Avid .....
    The best I have seen is the HQ setting in the 3D Warp tool and in Render Settings.  And that, if you dig enough in the doc, is described as "PolyPhase".  I have not found a great explanation of exactly what filter type that is.
    Bottom line, some Avid features seem to be designed for the lowest common denominator user, not the nit picky, image quality obsessed former DS users.  .... Sorry - that just slipped out.  Smile
    Jef
    Jef Huey
