Latest post Sat, Mar 17 2018 7:50 PM by Ken Lent. 10 replies.
Page 1 of 1 (11 items)
  • Mon, Mar 12 2018 3:03 PM
    dnxhd 80/85/100 subsampling?
    hello
    I keep reading that dnxhd 80 (or 85 or 100 - depending on the frame rate) is sub-sampled at 1440x1080
    Where/how can I see that in the Avid?  Is it still the case or is it now full raster size?
    https://en.wikipedia.org/wiki/List_of_Avid_DNxHD_resolutions#cite_ref-subsample1440_3-2
    Avid Media Composer 8.9.3 | Mac OS 10.13.2 | Editshare 7.2.1.2 [view my complete system specs]
  • Mon, Mar 12 2018 11:50 PM In reply to
    • Martin Fox
    • Joined on Fri, Mar 14 2014
    • Sydney Australia
    • Posts 224
    • Points 2,380
    Re: dnxhd 80/85/100 subsampling?
    Yes that was my experience when using DNX 85 last time I used it.
    The 1920 pixels were sub sampled to 1440 with non-square pixels rather like hdv
    it works ok, but does cause some problems If you need to use encoding software later,  that is it needs to support non square pixels and reformat your 1440 x 180 tp 1920*1080
  • Tue, Mar 13 2018 5:15 AM In reply to
    • Martin Fox
    • Sydney Australia
    • Posts 224
    • Points 2,380
    Oh! I checked, its now 1920 full raster, thats great, thanks for bringing this up, because I had stoped using it for offline, because of the encoding problems.
  • Tue, Mar 13 2018 7:59 AM In reply to
    great.  I thought it was but just couldnt find anything to suggest otherwise.
    Could you lead me to your findings?  thanks.
  • Tue, Mar 13 2018 1:18 PM In reply to
    It used to be the TR resolutions (Thin Raster) that subsampled down to 1440.
  • Tue, Mar 13 2018 2:25 PM In reply to
    • Posts 10,219
    • Points 218,265
    jimjams:
    Jimjams
    Can you email me your system ID and My Avid so I can get a case created and a verification to take place please?
    Martin - I have yours and will add you to the case.
  • Tue, Mar 13 2018 6:21 PM In reply to
    Pat Horridge:
    Pat, I think TR/Thin Raster is an HDV-specific thing. DNxHD80/85/100 definitely used to be subsampled -- maybe even still.
    See https://www.avid.com/static/resources/US/documents/dnxhd.pdf, see for exampe DNxHD85 in the middle of page 9, and note the '*' next to its 1920x1080 frame size, then note the annotiation on page 10, which says "subsampled to 1440x1080".
    There's also a 720 version called DNxHD50, which is subsampled to 960x720.
    I know MM is digging around for us to get definitive answers on this.
  • Tue, Mar 13 2018 11:22 PM In reply to
    • Martin Fox
    • Sydney Australia
    • Posts 224
    • Points 2,380
    I did a practical experiment, I transcoded some HD Dnx footage to DnxHR 85, checked the raster column in the statistics bin view, which detailed 1920 x1080. Next I exported same as source QuickTime and opened that file in QuickTime Pro which confirmed the size of 1920*1080. I then encoded the file to H264 in iFFmpeg (where I used to have to correct the aspect ratio to 16*9),and I got the same 1920*1080 result. Very useful offline Rez!
  • Wed, Mar 14 2018 5:55 AM In reply to
    Chris from Customer Support writes:
    In a 1080i/59.94 Project format with Raster Dimension 1440x1080 it's only DNxHD 100 and HDV 1080i.
    DNxHD 80 is available on a 1080p/24and 23 project format in both 1920 and 1440 raster dimension.
  • Wed, Mar 14 2018 8:11 AM In reply to
    • Ken Lent
    • Joined on Tue, Dec 18 2007
    • California
    • Posts 121
    • Points 1,275
    What is the earliest version of MC that supports the full-raster DNxHD 80?
    Core i7 930 PC 2.8GHz / 18GB RAM / Win7 Pro 64bit SP1 / nVidia Quadro K2200 (driver 375.86) / MC 8.8.5 (Symphony/PF/SS) / BCC AVX 10.0.2 / NewBlue Titler... [view my complete system specs]
  • Sat, Mar 17 2018 7:50 PM In reply to
    • Ken Lent
    • California
    • Posts 121
    • Points 1,275
    Also, how do you select between the 1920 and 1440 width options?
    Ken
