I have a dongle less system here that cant open Avid MC.
I am getting the Service Temporarily Unavailable error.
Pressing OK till the cows come home and still going.
I have to crash Avid to get in.
What's my next move?
When are you seeing that error?
Kevin Klimek: When are you seeing that error?
At startup.
Basically reboot Mac.
Select Avid MC in dock.
Beach ball for a few min.
See the splash for a second.
Then error pops up.
Press Ok a few hundred times.
Crash Avid MC and repeat.
Does AppMan say you are activated?
Not my day.
I now want to move the license to another system so I can work.
I get "There was an unspecified error (5) initializing the licensing engine" error :(
Kevin Klimek: Does AppMan say you are activated?
Thats been sitting at "Getting subscription data...." for hours.
Network is fine.
I can access all basic websites from this workstation.
End goal is to move this license over to another Mac Pro.
Can you try this.
Customers have reported a specific error “Error code: 5” relating to the licensing engine when launching the Media Composer | Software v8.x application.
Fix: Depending on the platform you have you will need to remove the following folder:
Note: This applies for both Application Manager and Avid License Control utilities in all versions 6.x - 8.x.
PC - Look for the following folders. If found, delete the entire folder.
C:\ProgramData\Avid\Licenses
Mac - Look for the following folders. If found, delete the entire folder.
Macintosh HD/Library/Application_Support/Avid/Licenses
Important: If you can’t find the specific folder in Windows, go to Folder Options in the Tools menu and select “Show Hidden Folders.”
Twitter: avidmarianna
www.avidcustomerassociation.com | Connect 2019 | April 6-7 | Aria, Las Vegas, NV
Marianna: Can you try this...
Can you try this...
Thanks that kinda worked.
But when opening Avid License Control I only see Avid MC 7.0/Interplay 7.0 with the ACTIVE button.
The Symphony shows a greyed out ACTIVATE button.
I am currently running MC 8.7.2 and would like to DEACTIVATE it from this problematic workstation.
Is there another option?
Can you email me or PM me the system ID?
