Latest post Sun, Mar 18 2018 6:56 PM by LKJ JKL. 5 replies.
Page 1 of 1 (6 items)
  • Thu, Mar 15 2018 5:21 PM
    • LKJ JKL
    • Joined on Tue, Jun 2 2009
    • Posts 128
    • Points 1,485
    h.264 in & out: which ist the fastest way?
    I have to ingest a +2 hour program (*.mov, h264) into the Avid. then simply remove some parts of the program and make a new h264/*.mov file for the client. No fx, no renders.
    What would be the smartest and fastest way to get this done?
    I would love to do it in PrPro but there is no CC on this system.
    so...
    TIA
    HP Z420 (E5-1650v2) | 32GB RAM | 250 GB SSD (OS) | NVIDIA Quadro P2000 | internal raid0 | AJA Io Express | Win7 Pro64 Sp1 | MC 2018.11 [view my complete system specs]
  • Thu, Mar 15 2018 7:35 PM In reply to
    Re: h.264 in & out: which ist the fastest way?
    1. Link to file.
    2. Make edits.
    3. Export.
    There may be a faster/smarter way, but this is my first thought.
    Media Composer 2018.12.5 w/Symphony/SS/PF options, HP Envy 17t-j100 Quad Edition laptop, Windows 10 Pro, Intel Core i7 2.4GHz, 16 GB RAM, nVidia GeForce... [view my complete system specs]
  • Thu, Mar 15 2018 8:58 PM In reply to
    SD HD 4K?
    The biggest the resolution the fastest the PC you need in order to AMA edit and export Same as Source.
    Having said that I would probably do what Carl suggests if I didn't have the time.
    Having more time I would transcode and then I would do the job faster (even on a lower spec PC).
    Desktop PC
    3 Heads Digital Films
  • Thu, Mar 15 2018 10:50 PM In reply to
    • v-block
    • Posts 537
    • Points 6,800
    By far the quickest way is to use something like 'Machete' or 'Avidemux'. All that is required is that the 'in' point after each edit is an I-Frame. Just drag the file in, cut out the required section and the output will simply copy whats left without any rendering. You can also select an in and out point, starting with an I-Frame and output just that section.
    http://www.machetesoft.com/
    http://fixounet.free.fr/avidemux/
    Asus X58 Sabertooth motherboard, Core i7 920 CPU, Win 7 Pro 64bit, NVIDIA GeForce GT610, 12GB Corsair 3x4GB CMX-12GX3M3A1333C9 ram in triple channel config... [view my complete system specs]
  • Fri, Mar 16 2018 3:50 AM In reply to
    • smrpix
    • Joined on Wed, Sep 5 2012
    • Posts 1,373
    • Points 16,955
    Two commercial products TMPGENC smart renderer and VideoReDo will allow you to make frame accurate edits and only recompress what's necessary around the cuts.  Very fast.
    (Also very good for merging spanned GoPro clips into a single file for Avid linking.)
  • Sun, Mar 18 2018 6:56 PM In reply to
    • LKJ JKL
    • Posts 128
    • Points 1,485
    Thank you so much for your suggestions and help!
    Have a great week
