Latest post Thu, Aug 2 2018 9:04 AM by luca.mg. 8 replies.
Page 1 of 1 (9 items)
  • Wed, Apr 4 2018 4:26 PM
    • jcmcnamee
    • Brooklyn, NY
    • Posts 234
    • Points 2,470
    matchframing color corrected multigroups goes to groups instead
    Hi, running MC 2018.3 with symphony. I have a sequence that has been working fine when matchframing multigroups...they open the multigroup. Now that I applied color corrections they are matchframing back to the groups that make up the multigroup instead of the multigroup. This machine was running 8.8.5 when I noticed this happening so thought maybe 2018.3 might have fixed it but the problem persists. Is this a known bug?
    Two other pieces of info:
    Matchframing via the audio tracks opens the multigroups, btw. So it's something that's happening to the video. Also, if i remove the color correction, the problem persists. So the color correction definitely does something to the multigroup in the sequence.
    Media Composer 2018.12.3 / OS 10.14.3 27" iMac [3.5 GHz Intel Core i7, 32 GB ram, NVIDIA GeForce GTX 780M 4GB] [view my complete system specs]
  • Sun, Apr 8 2018 9:19 PM In reply to
    • jcmcnamee
    • Brooklyn, NY
    • Posts 234
    • Points 2,470
    Re: matchframing color corrected multigroups goes to groups instead
    Is this expected the behavior? Problem persists in 2018.4
  • Tue, Jul 31 2018 3:56 AM In reply to
    • jcmcnamee
    • Brooklyn, NY
    • Posts 234
    • Points 2,470
    Problem persists in 2018.5
  • Tue, Jul 31 2018 9:32 AM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,582
    • Points 65,470
    I see this too on Wndows MC 2018.5.
    peace luca
  • Tue, Jul 31 2018 1:57 PM In reply to
    • Posts 10,280
    • Points 219,110
    Jim - I have support looking at this - case # 03521396.
    Luca - are you able to upgrade to 2018.7 and see if there is any change on this issue?
  • Tue, Jul 31 2018 2:50 PM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,582
    • Points 65,470
    Marianna:
    Ciao Marianna YesBig Smile I'm in the middle of a project that will last till 9/9, but I will certainly upgrade my donkey machine and spare some time to double check this, don't hold Your breath though, I'm fairly busy. Please note that I've seen many quirks with Match frame and group/multigroup clips years ago (mostly with renamed groups/multigroups) and never had the time to investigate, nor to report them, You know what is like when under heavy delivery pressure...
    peace luca
  • Wed, Aug 1 2018 1:26 AM In reply to
    • jcmcnamee
    • Brooklyn, NY
    • Posts 234
    • Points 2,470
    Thanks, Marianna! This is my first reproducible bug report. Looking forward to a future “what’s fixed!”
    Marianna:
    • jcmcnamee
    • Brooklyn, NY
    • Posts 234
    • Points 2,470
    Marianna:
  • Thu, Aug 2 2018 9:04 AM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,582
    • Points 65,470
    Tested with MC 2018.7 on my secondary system, this box has no Symphony option though, the one running MC 2018.5 referred to in my previous post had it, don't know if this does the difference, anyway, Matchframe to a colour corrected Multigroup loads the proper Multigroup. With a Multigroup Subclip however, Matchframe loads the Group instead, either colour corrected or not; this is a little annoyance I've encountered in the past years, from at least MC 6 on, as far as I remember, both PC and Mac, not tested on Symphony. Don't know if it's related, but it's there.
    peace luca
