Newscutter 10.5.4.26735, running on Windows 7 Pro SP1 64-bit. We're using ISIS shared storage. (Access version 2.7.5.33065 & ISIS Client 4.6.0.12200)
There are roughly 20 editing workstations on the system, and they're all working except one....
On the confused workstation... if I drag anything from the Interplay Tool into a bin... it comes up MEDIA OFFLINE. When I look at the bin, the "Drive" column is blank.. Again, I can drag the same media into a bin on any other workstation & it works fine.
Access 2.7.5 is ancient!!! Is ASF setup correctly? Is the workstation joined to the MI HAG? Restarted interplay services in workgroup properties? DNS issues on this machine? Can you ping by hostname?
Dave
"A very big network"
Yes, it's ancient:) An upgrade is in the works but I have to keep it going until then..
Turns out it indeed fell off the HAG. We're back in business...
