Latest post Thu, Nov 8 2018 12:06 PM by HansenPansen. 20 replies.
Page 2 of 2 (21 items) < Previous 1 2
  • Tue, Aug 7 2018 9:09 PM In reply to
    • Jonas
    • Joined on Thu, Jul 12 2018
    • Stockholm
    • Posts 4
    • Points 60
    Re: MC|F 2018.4 crashes unless AMPIPluginDSM.avx removed from package
    Ah ok that's the problem.
    I'll have to wait then..
    And maybe uninstall one of the programs meanwhile.
    Jonas
  • Wed, Aug 8 2018 12:26 AM In reply to
    • Martin Fox
    • Joined on Fri, Mar 14 2014
    • Sydney Australia
    • Posts 223
    • Points 2,365
    I’ve had this problem too. I moved all the plugins out of the AVX2 folder and MC worked. I then put the plugins back one at a time to find the problem ones. They ALL went back without! problem! Though occasionally MC still crashes on start up, but will be successful on second launch.
  • Thu, Aug 23 2018 9:06 AM In reply to
    Hello Marianna,
    same problem here. PT working fine daily and AMPI error while launching MCF.
    Thank you for the plugin list, I think I use ALL of them !! Big Smile
    I don't intend to use them in MCF, but I don't know how to unable or bypass the plugins check at launch.
    Thank you !!
  • Thu, Aug 23 2018 2:05 PM In reply to
    • Posts 10,215
    • Points 218,190
    Laurent
    The only way is to move the plug in folder to the desktop each time you wish to launch MC since all of the offending plug in's are in your system.
    Then when done, go back and plop it back in the original location and use PT.
    You can also see if any of the "offending plugs" have upgrades from the 3rd parties....
  • Fri, Aug 24 2018 7:17 AM In reply to
    Same here. Premiere works perfectly. Without any "removing of your plugins folder before launch"
    (I'll keep seeing some twitter posts about how great MC is for editing Star Wars and such...)
  • Thu, Nov 8 2018 12:06 PM In reply to
    I had the same Problem - after update to MC 2018.10 Avid crashed on startup when loading AMPIPluginDSM.avx
    It did'n help to just move the "AVX2 Plugin" folder to the desktop - result was the same - the Solution was that I also had to move the Avid-Audio-Plugins folder (Library/Application Support/Avid/Audio/Plugins) over to the desktop. After a successful start of Media Composer I have moved the plugins back to the old location in small chunks to find the culprit. Eventually I ended up keeping only the plugins I really needed from within Avid - so all NI and other DAW Plugins stayed out of the folder.
