Latest post Sun, Dec 9 2018 7:08 PM by BobRusso. 55 replies.
Page 3 of 4 (56 items) < Previous 1 2 3 4 Next >
  • Thu, May 31 2018 8:44 PM In reply to
    • hodgesjl
    • Joined on Fri, Feb 1 2013
    • Posts 15
    • Points 165
    Re: iMac Pro and ISIS 5500 not playing well together
    I installed 18.5 and restarted. I was able to copy files from the ISIS to my desktop up to 95MB but it errors out with any file I tried over 220MB (didn't have files between 95 and 220 to try) The playback also chokes right away if I try to play movies located on the ISIS workspace. Thanks for sticking with us.
  • Thu, May 31 2018 9:46 PM In reply to
    • RicardoG
    • Joined on Wed, May 23 2018
    • Posts 5
    • Points 75
    Same thing for me.  Installed 18.5, restarted my computer.  My copy of files from the ISIS to my desktop only made it to 8MB before it errored out.  Launched Media Composer and the playback stopped after a few seconds.  I can still copy things to the ISIS without any issues.  Thanks for the help.
  • Thu, Jun 21 2018 11:35 PM In reply to
    • NickFJ
    • Joined on Thu, May 24 2012
    • Sydney
    • Posts 23
    • Points 215
    Hi folks, FYI - this is going on in Mac Media Composer forum as well:
    http://community.avid.com/forums/t/184765.aspx
    Cheers - Nick
    Avid Media Composer 7.0.2 Mac OS X 10.8.5 iMac 3.4 Ghz Intel Core i7 16GB RAM Promise T/bolt 4TB Raid Lacie T/bolt 6TB Raid [view my complete system specs]
  • Thu, Jun 21 2018 11:49 PM In reply to
    • RicardoG
    • Posts 5
    • Points 75
    I've found a solution (actually Avid support gave me a solution).  I'm connected now with a USB-C to Gigabit Ethernet adapter and the problem seems to have completely gone away.  Earlier in this thread it was mentioned that we shouldn't connect that way but it's working for me.
    Would love to know if this works for anyone else.
  • Tue, Jun 26 2018 6:48 PM In reply to
    • BobRusso
    • New Jersey
    • Posts 2,243
    • Points 27,700
      Moderator: Avid ISIS
      Moderator: Avid NEXIS PRO
    NEXIS 18.6 was released and has a couple of fixes in the client manager specific to the Mac and iMac Pro. I encourage you upgrade to this client.
  • Tue, Jun 26 2018 7:27 PM In reply to
    • hodgesjl
    • Posts 15
    • Points 165
    I  upgraded my iMac Pro to 18.6, but am still getting the -36 error message when trying to copy files from the ISIS server to my desktop. Can copy some sub 50MB files but it is hit or miss if I get the -36 error.
  • Tue, Jun 26 2018 8:26 PM In reply to
    • hodgesjl
    • Posts 15
    • Points 165
    ***UPDATE***
    On a whim, I tried using a USB 3.0 to GigE adapter to connect to the ISIS and sure enough, I can now play files from the ISIS, copy files from the ISIS - no errors. Whodathunkit???
  • Tue, Jun 26 2018 8:34 PM In reply to
    • BobRusso
    • New Jersey
    • Posts 2,243
    • Points 27,700
    hodgesjl:
    ***UPDATE***
    With NEXIS 18.6, this is officially supported. I'm not sure why the built-in Ethernet isn't working for you.
  • Tue, Jun 26 2018 10:05 PM In reply to
    • RicardoG
    • Posts 5
    • Points 75
    I've also upgraded to 18.6 and connected via the built-in Ethernet and it doesn't work for me either.  Error -36 when copying from the ISIS to my desktop.
    Connecting through USB-C to Ethernet adapter works.
  • Tue, Jun 26 2018 11:25 PM In reply to
    • Posts 10,088
    • Points 216,600
    RicardoG
    The mac oS error -36 problem stems from the “dot-underscore” companion files that Mac OS X's HFS+ filesystem creates for files when they get moved to FAT16 or FAT32 volumes. The problem is observed when folders from a Windows-compatible volume get moved to a Mac and then back again. The dreaded “Error Code -36″ message is the result.
    If you are experiencing this problem, you can run a simple dot_clean utility to remove the hidden "dot-underscore" files from your drive.
  • Wed, Jun 27 2018 5:19 PM In reply to
    • Posts 10,088
    • Points 216,600
    Folks
    Getting a case created for this so we can get the bug identified looked at.
    Adding most of you to the case as long as I can find your email.
  • Wed, Oct 24 2018 2:16 AM In reply to
    Hey Marianna -
    Looks like same thing for me too.
    Nexis 18.9
    Avid. 8.10
    ISIS 5500 (4.7)
    on 2018 iMac Pro (10.13.6)
    Usb-C adapter works but not the build in NIC
    Chris
    Computer: Apple 27" iMac Late 2013 Apple 13" MacBook Pro Retina Early 2013 Intel i7 920 / Asus P6T Deluxe / 12GB / FX1800 / 64GB SSD Boot / 500... [view my complete system specs]
  • Wed, Oct 24 2018 1:40 PM In reply to
    • BobRusso
    • New Jersey
    • Posts 2,243
    • Points 27,700
    This is a known issue - connecting 1GigE using the built-in 10GigE NIC in the iMac Pro to ISIS. 10 and 1GigE works with NEXIS and 10GigE works with ISIS. The current workaround is to use the USB adapter.
  • Fri, Oct 26 2018 4:11 AM In reply to
    • psm
    • Joined on Sun, May 31 2015
    • Posts 1
    • Points 5
    Same issue here. I am using i mac pro 2017 and installed both NEXIS and ISIS also. When trying to copy file from NEXIS to system or any hard same error code. Unable to copy any file from storage.
  • Thu, Nov 29 2018 10:52 PM In reply to
    • evoavid
    • Joined on Tue, Sep 23 2014
    • Posts 4
    • Points 40
    What's the official Avid bug tracking #? When is this going to be fixed? Avid has been aware of this specific issue since at least April 2018.
    Workarounds like this are for free software, not commercial software where users and companies pay thousands for annual support.
