Latest post Tue, May 1 2018 1:59 PM by MattB. 4 replies.
  • Fri, Apr 27 2018 11:50 AM
    • MattB
    • Joined on Tue, May 9 2006
    • Shepperton, UK
    • Posts 472
    • Points 6,420
    Boris Red library missing
    When I launch Boris Red from within MC all is fine except that the library of effects is not available, but otherwise I can use as expected.
    If I launch RED as a stand alone I get this message. If I OK it, Red starts up and is fine as long as I dont need any of the library effects.
    I have uninstalled and re-installed to no effect - Any ideas?
    This is on my edit 1 system - Windows 7, MC 8.10, Quadro 4000 (dirver 377.11)
    Matt
    Edit 1:- Intel Core i9 7900X msi x299-SLI-plus mobo 32GB DDR4 3000Mhx memory NVIDIA Quadro P4000 (Nvidia driver 411.95) Samsung 860PRO SSD 512GB system... [view my complete system specs]
    Matt B
    Filed under: , ,
  • Fri, Apr 27 2018 6:42 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,567
    • Points 45,810
    Re: Boris Red library missing
    It sounds like the installer is corrupted. Download a new copy from Boris and try installing that instead. You may want to rename the dll file also before installing to make sure you get a new copy.
    Dave S.
  • Sat, Apr 28 2018 2:47 PM In reply to
    • MattB
    • Shepperton, UK
    • Posts 472
    • Points 6,420
    Hi Dave,
    Thanks for the suggestion - I have tried re-installing from a fresh download but still no change I'm afraid.
    I have opened a ticket with Boris support - and that was their first response too; so im in an ongoing dialogue with them at the moment.
    Didnt try renaming the DLL file - I assume you are talking about the one refered to in the error message.
    Matt B
  • Tue, May 1 2018 12:02 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,567
    • Points 45,810
    MattB:
    Correct.
    Dave S.
  • Tue, May 1 2018 1:59 PM In reply to
    • MattB
    • Shepperton, UK
    • Posts 472
    • Points 6,420
    I did that.
    Actually the DLL file was in a the Matrox Programme files folder. I didn't get a new, clean file but I have stopped getting the error message. I assume therefore that the DLL file was something to do with having RED interface with my MXO2, which I am happy do do without!
    As for the missing library browser, well that is a bit embarrasing! The two things (missing library & error message) were obviousley not connected at all as I had assumed. I fixed the library browser by making it open in a window with more real estate and then I could see it all; it had been there all the time! What a clutz!
    Anway - thanks for taking the time Dave.
    Matt B
