Latest post Fri, Feb 15 2019 12:05 AM by Eric. 3 replies.
  • Wed, May 9 2018 6:03 PM
    • LPG
    • Joined on Fri, Dec 9 2005
    • Venice, CA
    • Posts 116
    • Points 1,430
    Sequence too long... Avid 2018.4
    Hello,
    I'm currently getting the following error on long sequences in Avid 2018.4.0, working in Mac 10.11.6
    In past versions of Avid I would click the playlength button and this would go away. For this version, if I click the playlength button it will let me play the sequence, but as soon as I make a change to the sequence the error pops up again. Is there a workaround to make this stop popping up in this version please?
    -LPG
  • Wed, May 9 2018 8:29 PM In reply to
    • jef
    • Joined on Sun, Feb 26 2006
    • Maryland
    • Posts 3,430
    • Points 41,355
    Re: Sequence too long... Avid 2018.4
    I have seen something similar when I made a stringout of material using AutoSequence and source clips TCs stretched longer than 12 hours.
    Example: First clip has TC of 09;00:00:00 and lasts for 1 sec.  Last clip in sequence has TC of 20;00;00;00 and last for 1 sec.  Nothing in between.
    That message might come up.  Avid seems to not like a sequence longer than 12 hours.  My solution was to cut out the gaps.  Sort of sucked, but got me where I needed to go.
    Just guessing in your case.
    Jef
    Jef Huey
  • Wed, May 9 2018 10:51 PM In reply to
    • LPG
    • Venice, CA
    • Posts 116
    • Points 1,430
    Hi Jef,
    Yes that's the same issue I'm having. I used to be able to use the playlength button to alleviate this problem but it doesn't seem to be working the same in this version of Avid.
    -LPG
  • Fri, Feb 15 2019 12:05 AM In reply to
    • Eric
    • Canada
    • Posts 561
    • Points 6,400
    I just started getting this error after receiving an updated sequence that I imported into a working Avid project.
    I cant seem to find a fix anywhere here.
    Mac Pro (Late 2013) Apple OS X 10.13.6 MC 2018.10.0 Avid Arist I/O [view my complete system specs]
