Latest post Thu, May 17 2018 12:18 AM by Jason NLC. 6 replies.
Page 1 of 1 (7 items)
  • Wed, May 16 2018 7:54 PM
    • Jason NLC
    • Joined on Thu, Jun 13 2013
    • Posts 124
    • Points 1,740
    Color Bars Look too Bright
    I just installed the latest version of media composer.  I imported HD_1080 SMPTE_BARS to check that my monitors are calibrated properly for color correction.  Oddly, the bars appear very bright (versus the way they looked on my previous version of avid).  If I calibrate to these bright bars, my video footage becomes extremely dark -- blacks are crushed.  I know that the footage wasn't shot this way.  Am I importing the bars wrong?  Do I need to change any import settings?  Something is off.
    Thanks for the help!
  • Wed, May 16 2018 8:16 PM In reply to
    Re: Color Bars Look too Bright
    If you imported it using traditional Import command make sure you indicated the correct color space. It should be 16-235 video range and not full 0-255 RGB range.
    If you AMA'd it, check Source Settings for the same issue.
  • Wed, May 16 2018 9:17 PM In reply to
    • Jason NLC
    • Posts 124
    • Points 1,740
    It sounds like you are on to something.  I can't find the place to change these settings on import or AMA.
  • Wed, May 16 2018 10:04 PM In reply to
    • Jason NLC
    • Posts 124
    • Points 1,740
    When I imported the bars, my color levels were set to:  SCALE FROM FULL RANGE TO LEGAL RANGE.  When I change it to:  DO NOT MODIFY, TREAT AS LEGAL RANGE, the bars import darker and seem to be at the correct levels.  Is that accurate???
  • Wed, May 16 2018 11:23 PM In reply to
    Check them on the Waveform Monitor in Color Correction mode (after import I mean). But yes, I would expect color bars etc would need to be imported without any luma level changes.
    You mention things looking “right”, but I don’t know which type of monitor you are looking at. If you’re looking at computer monitors or video monitors.
    Also, this might help: http://www.jobterburg.nl/Publications/601_709_RGB.pdf
  • Thu, May 17 2018 12:00 AM In reply to
    • Jason NLC
    • Posts 124
    • Points 1,740
  • Thu, May 17 2018 12:18 AM In reply to
    • Jason NLC
    • Posts 124
    • Points 1,740
    I believe that setting put me back on track.  I am sure that's what I had my last software set on and I did it once and never looked back.  Thanks for the help.
