Latest post Tue, May 22 2018 12:04 PM by LDV20. 6 replies.
Page 1 of 1 (7 items)
  • Fri, May 18 2018 12:43 PM
    • LDV20
    • Joined on Fri, Nov 18 2011
    • Posts 158
    • Points 1,880
    Trim windows video Missing in Trim mode with unrendered effect
    My video in the Trim windows are missing - it might have happened after 2018.4 upgrade. Both source and record windows are black.  What could be the problem?
    thank you
    EDIT - It has do with an unrednered effect - I am using the time wrap effect on the clips - I am wondering if there is something I am not doing properly - or my computer cannot handle the trim mode with un rendered effect
    Symphony 2018.8 - Win 10 pro, Asus PrimeZ270 with i7 7700 cpu, Quadro P2000,32gig memory, 500gig SSD system drive, WD 5TB,and 2TB media drive,BM Intensity... [view my complete system specs]
  • Sat, May 19 2018 8:19 AM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,358
    • Points 62,855
    Re: Trim windows video Missing in Trim mode with unrendered effect
    Not in front of a system right now, so I can't tell You where that is, but there's a setting to allow realtime preview in trim mode. Be aware that blue dot effect clips won't display even with the proper setting on.
    Symphony 2018.5, BM Intensity Pro 4k, Windows 10, i7-5930K, 32 GB ram, Quadro K620 [view my complete system specs]
    peace luca
  • Mon, May 21 2018 1:10 PM In reply to
    • LDV20
    • Posts 158
    • Points 1,880
    Thank you - will look for that setting.
  • Mon, May 21 2018 2:16 PM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,358
    • Points 62,855
    It's "Trim settings", "Render on the fly". HTH
    peace luca
  • Mon, May 21 2018 5:30 PM In reply to
    • LDV20
    • Posts 158
    • Points 1,880
    Ok will enable it - funny thing never had this problembefore.  I also read (somewhere in a readme file)  in order to do BG renders the CPU needs six-cores.   Mine cpu I7 is only four and BG renders do not work - perhaps I did not enable something, not sure or BG renders do not work with four cores - is that correct?
    thank you
    larry
  • Tue, May 22 2018 9:11 AM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,358
    • Points 62,855
    LDV20:
    It should be off by default, but if You upgrade from a previous version and carry over the old user settings (not always a wise choice) You might have it already set on previously.
    I don't know much about hardware requirements for background tasks, I'm sorry sorry mate.
    peace luca
  • Tue, May 22 2018 12:04 PM In reply to
    • LDV20
    • Posts 158
    • Points 1,880
    Yes - I think it happened on 2018.4 update.   Thank you for your help - I will figure it out
    thanks
