Latest post Wed, Jul 25 2018 9:36 AM by GT. 6 replies.
Page 1 of 1 (7 items)
  • Wed, May 23 2018 7:31 PM
    Export Problem Avid
    Hello. I know this is probably a known topic but I never found a good solution for it. When I try to export a Quick time movie file from avid the video is way darker than it should be. Is there a way to fix this issue inside avid or should I use different software? I cannot use squeeze cause I can't afford it as of right now. If there is any other software I could use for exporting how would the roundtrip be? Like what codec or file should I use to export it out of Avid and send it to a software that can export the video without gamma issues.
    Thank you!
  • Thu, May 24 2018 3:33 PM In reply to
    Re: Export Problem Avid
    The Apple codec is notorious for gamma shift.   That's why it is always recommended to export as a same-as-source file and then use an outside encoder like Squeeze.   I own the Pro version, but doesn't Squeez Lite come bundled with MC?
    MC 2018.4 with Symphony, Matrox MX02 Mini Max, Win 7 Pro, HP Z800 2x6-Core 3.2Ghz Xeon, 48GB ram, Quadro K4200, SanDisk Extreme 240GB SSD as system drive... [view my complete system specs]
  • Thu, May 24 2018 3:46 PM In reply to
    If you don't have an outside encoder and you are on a PC, you can export as a WMV or AVI file.   These don't have the same gamma shift problems.
  • Wed, May 30 2018 2:10 PM In reply to
    • Mark
    • Joined on Sun, Dec 19 2010
    • Posts 432
    • Points 4,660
    There are several freeware programs video encoding programs available. Rumage through sourceforge, github & alternativeto for suggestions. Handbreak & FFMpeg are goto options if either meets your needs. Also, is Sorenson Lite still bundled w/MC? It outputs MC H.264, Sorenson MPEG-4, MP4, VP8, WebM, Sorenson Spark, H.263, VP6, FLV. https://www.sorensonmedia.com/squeeze/squeeze-desktop/squeeze-lite/
  • Tue, Jun 5 2018 6:07 AM In reply to
    Hello! I tried using AVI to export but my project is 23.98 fps and the only option the Avi codec gives me is 24, 30, etc.
    Also, I tried exporting an AFF file to DaVinci to try exporting from there but the gamma is already shifted! I even relinked to the camera files and the gamma is still shifted! I don't understand what is happening. Also, I tried exporting a quick reference file to media encoder but the program cannot import the reference file! Maybe I'm choosing the wrong settings when I'm exporting. HELP PLEASE!
  • Wed, Jul 25 2018 9:29 AM In reply to
    • RY
    • Joined on Sat, Dec 17 2011
    • Posts 15
    • Points 160
    Encoder used to be great for creating a file out of Avid's quick time reference. Recently it doesn't work any more. I managed to find some settings which worked, but every project I have to research from start.
    Try this:
    Output> Export to File>
    Export Settings: Untitled. Options> Export As: Avid Media Processor.
    Check the "Render Unrendered  Effects" if needed
    Choose your sound settings
    Worked fine with encoder!
  • Wed, Jul 25 2018 9:36 AM In reply to
    • GT
    • South Africa
    • Posts 378
    • Points 4,115
    The latest version of Media Encoder no longer supports QT reference files and QT 7 codecs
    See here: https://helpx.adobe.com/x-productkb/multi/quicktime7-support-dropped.html
    The previous version (2017) still works.
    MC Ver 8.7, Intel Core I5, NVidia Quadro FX 570, 16Gb Ram, 250 Gb system drive, 2 Tb Render/Media drive, Windows 7 64bit Pro, QT 7.6.6 [view my complete system specs]
