Latest post Wed, Jun 13 2018 6:54 PM by gorbi. 6 replies.
Page 1 of 1 (7 items)
  • Wed, May 23 2018 10:23 PM
    frame flex problem MC2018-5
    hello,
    I strat with MC 2018-5, but the frame flex don't run correctly. I use PC.
    When I want change the frame flex from 16/9 to 2.1 , I can see the grid changing in 2.1 but no black mask, the result don't change. I think is a bug with this news version.
    Please help me !
    Thank's
    Christophe
  • Thu, May 24 2018 7:04 PM In reply to
    • Posts 9,259
    • Points 206,095
    Re: frame flex problem MC2018-5
    What OS?
    This is weird....   so you see the green dot showing that FrameFlex is in action and correctly sets the aspect ratio on the clip in the sequence?
    What happens if you update the sequence by right-clicking on the sequence, then selecting Refresh Sequence -> Aspect Ratio and Reformatting Options?
    AOL IM:  avidmarianna
    Skype: mariannamontague
  • Wed, Jun 13 2018 12:18 PM In reply to
    • gorbi
    • Joined on Mon, Mar 31 2014
    • Posts 6
    • Points 90
    Hi Marianna
    I've the same issue here. Just tested 2018.5 on OS X 10.12.6 and 10.13.4.
    Frame Flex Letterbox/Pillarbox setting on AMA Links, Masterclips or Subclips does not apply in source settings window, source nor at record monitor. The grid looks correctly but no black bars are shown. Scale, Center & Crop seems to work.
    Issue exists on existing projects or newley created ones. Also creaed a new user settings, it doesn't help.
    Source Setting Frame Flex is applied to clip in timeline and effect symbol showed correctly (green dot).
    Changing in effect editor does also not as well as refresh sequence does not help, bars are not shown at all.
    Best,
    Norbert
    MacBook Pro (Late 2011), 2.5 GHz Intel Core i7, 16 GB 1333 MHz DDR3, AMD Radeon HD 6770M 1024 MB, OS X 10.9.2, AVID MC 6.5.4.2 [view my complete system specs]
  • Wed, Jun 13 2018 12:37 PM In reply to
    • Posts 9,259
    • Points 206,095
    Zebra and Gorbi
    I have created a case on this # 03492191
    Support will get on it asap.
  • Wed, Jun 13 2018 1:17 PM In reply to
    • Helpyou
    • Joined on Thu, Sep 25 2008
    • Posts 25
    • Points 325
    Hi Marianna,
    Please see this:
    MCCET-2462 | MC - FrameFlex bug (Slam Disques) [Case : 03474811]
    Thanks!
  • Wed, Jun 13 2018 1:26 PM In reply to
    • Posts 9,259
    • Points 206,095
    Helpyou:
    Hi Marianna,
    Please see this:
    Thanks!
    Yes should have caught that.  Fixed in 2018.5.1 which wasnt released but will be out in 2018.6 this month.
  • Wed, Jun 13 2018 6:54 PM In reply to
    • gorbi
    • Posts 6
    • Points 90
    Great! Thanks a lot for your fast reply. Hope 2018.6 will be released soon since we are setting up all editing workstations at our school in the next few days.
    Best,
    gorbi
