Latest post Tue, Jun 12 2018 8:39 PM by Marianna. 9 replies.
Page 1 of 1 (10 items)
  • Wed, Jun 6 2018 6:19 AM
    • Erik
    • Joined on Thu, Oct 5 2006
    • Austin, TX
    • Posts 176
    • Points 2,105
    Source/Record windows display wrong color
    I just installed the latest release of Media Composer (2018.5) on a fresh install of Windows 10 pro on a new system. I created a fresh user profile.
    I was shocked to see that once I AMA linked some footage, the color of the video in the source/record windows was incorrect, looked almost inverted.
    I checked the Source Settings of the clip and oddly enough the preview window there shows the correct colors for the clip.
    The source and record windows are are set for Rec.709 full range, but any setting I choose from the display color space window doesn't have an impact on the colors.
    The project is set for the default YCbCr 709 color space.
    I can't find any other setting I would think would change this.
    I also have Adobe Premiere Pro, After Effects and Davinci Resolve installed and they all show the correct colors for these clips.
    Source Record windows
    Source Settings
    Graphics card is a Nvidia Geforce GTX-1070 TI, connected to a Dell UP2718Q 4k display. Windows 10 Pro 64-bit.
    Intel Core I9 7940x (14 cores), 64GB of DDR4 memory installed.
    MC 2018.4 Dell Precision 7710 mobile workstation, 64GB of memory, Xeon E3-1535M v5 @2.9Ghz, Nvidia Quadro M5000m. Running Win10 64bit. MC 2018.5 Asus... [view my complete system specs]
  • Wed, Jun 6 2018 6:39 AM In reply to
    Re: Source/Record windows display wrong color
    It is a known problem with 2018.5 and some GeForce cards that is being worked on.  For me the best solution was to revert to 2018.4, (same video card as you)
    There is a fix that works for some. In MC's Video display settings disable the Dual Copy Engine option.  This also worked for me but a couple of others had issues with it.
    Hopefully the next update will fix this.
  • Wed, Jun 6 2018 11:53 AM In reply to
    • Erik
    • Austin, TX
    • Posts 176
    • Points 2,105
    Thanks. I'll roll back to 2018.4 and see what happens. I'll post an update later.
  • Wed, Jun 6 2018 12:45 PM In reply to
    • Erik
    • Austin, TX
    • Posts 176
    • Points 2,105
    Happy to report that rolling back to 2018.4 fixed this.
    Thanks for your help!
  • Thu, Jun 7 2018 8:48 PM In reply to
    • Posts 9,260
    • Points 206,120
    A fix is in the works... the rub is that those cards were Not approved even though many of you got them to work.  Now we need to deliver a fix to make everyone happy.
    p.s thanks Andrew for the catch :)
    AOL IM:  avidmarianna
    Skype: mariannamontague
  • Fri, Jun 8 2018 10:05 AM In reply to
    • Fabrice
    • Joined on Wed, Oct 5 2011
    • Paris, France
    • Posts 4
    • Points 30
    Hello,
    I've got this bug too. But how to roll back to 2018.4 ? Where can I find the installer ?
    Thank you ! ;-)
    Avid MC 2018.05 Windows 10 64bits [view my complete system specs]
  • Fri, Jun 8 2018 10:53 AM In reply to
    • Fabrice
    • Paris, France
    • Posts 4
    • Points 30
    It's ok, I've found it: http://www.avid.com/media-composer/learn-and-support
  • Fri, Jun 8 2018 2:51 PM In reply to
    • Atomike
    • Nebraska
    • Posts 712
    • Points 10,850
    Marianna:
    A fix is in the works... the rub is that those cards were approved even though many of you got them to work.  Now we need to deliver a fix to make everyone happy.
    This is very good news!  I appreciate the work going into this. Smile
    Media Composer 8.X (usually newest release), Avid matrix-recommended versions of both Nvidia driver and Quicktime, Matrox Mini MX02, Self-built machine... [view my complete system specs]
    I spend most of my time between New York and Los Angeles.  In Nebraska.
  • Tue, Jun 12 2018 8:26 PM In reply to
    • fropdaddy
    • Posts 9
    • Points 135
    I have the same issue.  I disabled the "Dual Copy Engine" option and it did fix it for me.
    Anyone know what that setting does?
  • Tue, Jun 12 2018 8:39 PM In reply to
    • Posts 9,260
    • Points 206,120
    Fropdaddy
    Dual Copy Engine - is a new Video Display Setting option, Dual Copy Engine, which enables loading data to GPU from multiple threads.   Most with the issue with this color change come up on systems with non suported video cards.  While we did expand what cards could sneak under the radar with this new option setting, now we need to fix this.
    Expected to fix in 2018.6 I think
