Latest post Fri, Jun 15 2018 7:21 AM by Kieran Toman. 2 replies.
  • Thu, Jun 14 2018 1:19 PM
    • Kieran Toman
    • Joined on Wed, May 9 2018
    • Posts 7
    • Points 80
    [SOLVED] Install Failed: AvidNEXISSetup_Pro_Firmware_r4.1.7b1_v2
    We are attempting to update our Avid Nexis Firmware to r4.1.7b1_v2 as per someone else's request. We were also told to install firmware update 4.1.16d first.4.1.16d installed correctly and perfectly however now whenever we attempt to install r4.1.7b1_V2 we are presented with an installation failed error. I am unsure if this is because we already have this firmware installed or other reasons.
    Is there a way to view the previously installed firmware? The install logs did not provide any information.
    Are these two firmware updates compatible?
    If anyone has any advice it would be really appreciated.
    Filed under: , , ,
  • Thu, Jun 14 2018 7:03 PM In reply to
    • BobRusso
    • New Jersey
    • Posts 2,258
    • Points 27,890
      Moderator: Avid ISIS
      Moderator: Avid NEXIS PRO
    Re: Install Failed: AvidNEXISSetup_Pro_Firmware_r4.1.7b1_v2
    This firmware is only for the NEXIS PRO 20, I assume you have a PRO 20. The PRO 40s should have the firmware updated or have a different controller that doesn't require this.
    4.1.7 is earlier version vs 4.1.16. We've pulled 4.1.7 off my.avid.com and you shouldn't attempt to install it. All updates in 4.1.7 are included in 4.1.16. There's no value in the 4.1.7 firmware and whoever gave it to you please instruct them that it should be deleted.
  • Fri, Jun 15 2018 7:21 AM In reply to
    • Kieran Toman
    • Posts 7
    • Points 80
    Consider it deleted! Thank you very much :)
