Latest post Thu, Jun 28 2018 2:36 AM by tiidavid. 6 replies.
Page 1 of 1 (7 items)
  • Mon, Jun 25 2018 6:19 AM
    • tiidavid
    • Joined on Thu, Mar 19 2015
    • Posts 13
    • Points 165
    What is 'Render Unrendered Effects' check-box of AMA file export dialog box for?
    Hi
    There is 'Render Unrendered Effects' check-box in the AMA file export dialog box. I enabled it and exported a sequence which consists of three P in P effects those are not rendered, master clips which used on that sequence are XAVC 4K intra CBG Class 300 media files.
    Export setttings: Export As: Avid Media Processor, Video compression: XAVC 4K Intra CBG Class 300, Enable Sony XAVC Intra 4K constraint. I could not find any rendering processing on the computer, but exported file successfully created.
    Next I disabled 'Render Unrendered Effects' check-box and exported the same sequence. I could not find any rendering processing on the computer, but exported file successfully created.
    No visible difference shown between enabling and disabling 'Render Unrendered Effects' check-box. In addition result is the same whether enabling or disabling 'Render Unrendered Effects' check-box.
  • Mon, Jun 25 2018 9:43 AM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,633
    • Points 66,110
    Re: What is 'Render Unrendered Effects' check-box of AMA file export dialog box for?
    Do You get a duplicate sequence with the "exported" suffix after export? If yes that's where the rendered effects will be shown.
    Symphony 19.12, BM Intensity Pro 4k, Windows 10, i7-5930K, 32 GB ram, Quadro K620 [view my complete system specs]
    peace luca
  • Tue, Jun 26 2018 4:50 AM In reply to
    • tiidavid
    • Posts 13
    • Points 165
    No. I do not get .duplicated or .Rendered sequence. I expected, but not.
    Has anyone tried it? I am using MC version: 2018.5 Win. Older version may work.
  • Tue, Jun 26 2018 10:50 AM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,734
    • Points 61,780
    What happens if you have a blue-dot effect in your sequence?
    Camera(s) PXW-X70, HDR-FX1, Hero 6 Black | MC 2019.12 | QT 7.7.9 | Continuum 2020 | Sapphire 2020 | Mocha Pro 2020 | Titler Pro 7 | Windows 10 Pro x64... [view my complete system specs]
    Steve
    ______________________
    www.nelliedogstudios.com
  • Wed, Jun 27 2018 12:57 AM In reply to
    • tiidavid
    • Posts 13
    • Points 165
    I am just asking functionality of 'Render Unrendered Effects' check-box of AMA file export dialog box. What is used for?
  • Wed, Jun 27 2018 9:50 AM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,734
    • Points 61,780
    I was asking about blue dot effects because they may require rendering before AMA export. Green dot effects may not and perhaps that's why you aren't seeing a difference with and without that option set. I don't really know the answer to your question - thought you might want to experiment.
    Steve
  • Thu, Jun 28 2018 2:36 AM In reply to
    • tiidavid
    • Posts 13
    • Points 165
    Thank you, Steve.
    I tried a sequence with blue dot effect. Whether enabling or disabling 'Render Unrendered Effects', resulted exported file was created with all effects rendered. No .duplicated sequence created.
    I do not know specification but it seems we do not need to enable it when we want to get 'rendered' result by latest Media Composer. I cannot try every effects so it may be some we need to enable it when we want to get 'rendered' result, or may not.
