Latest post Thu, Jul 5 2018 11:56 AM by Roger Owen. 6 replies.
Page 1 of 1 (7 items)
  • Wed, Jul 4 2018 11:19 AM
    • Roger Owen
    • Joined on Wed, Jun 21 2006
    • The New Forest, South Coast, UK
    • Posts 98
    • Points 1,230
    Importing AAF from one Avid to another Avid
    I can find lots of guidance to Export but not Import, maybe I#m using the wrong terminology?
    2 x Avid Xpress Pro 5.x with SDI Mojo, 1 x Avid Xpress DV 4.x, all running on home-built PC's with single core processors. Sony Digibeta and DVcam... [view my complete system specs]
    Lots of kit... only one pair of hands!
  • Thu, Jul 5 2018 10:28 AM In reply to
    Re: Importing AAF from one Avid to another Avid
    Set your media creations to where you want your media to go(if there is any).  Make a new bin.  Drag and drop the AAF into the new bin.
    MC/SN 2018.6+7+8+9 x 15 Z400/420/440 PC's 2 x Mac, 4 x PT 12.8.1 HDX all on PCs. [view my complete system specs]
  • Thu, Jul 5 2018 10:48 AM In reply to
    • Roger Owen
    • Posts 98
    • Points 1,230
    Thanks. I did try that - but media still offline.
  • Thu, Jul 5 2018 11:18 AM In reply to
    Is it an embedded AAF?
  • Thu, Jul 5 2018 11:37 AM In reply to
    • Roger Owen
    • Posts 98
    • Points 1,230
    No, seperate media files.
  • Thu, Jul 5 2018 11:51 AM In reply to
    • dbiok
    • Joined on Fri, Mar 19 2010
    • Germany
    • Posts 43
    • Points 515
    Hi Roger,
    make sure to copy the MediaFiles-folder delivered with the aaf onto your MediaFile-Disk (be aware of the folder structure). Maybe there is a already a mdb/pmr inside, but I would say you have to scan it (let MC do the job).
    If you are in an ISIS/Nexis environment make sur you have the right naming for the folder, so your MC can see and scan it.
    After the scan, your files should be online.
    so long & thx
    dbiok
    [3x MediaComposer 2018.7 @ NitrisDX || HP Z800 Workstation (Dual XEON X5570) || Win10 64Bit] - [1x Symphony 2018.7 @ NitrisDX || HP Z800 Workstation (Dual... [view my complete system specs]
  • Thu, Jul 5 2018 11:56 AM In reply to
    • Roger Owen
    • Posts 98
    • Points 1,230
    Thanks, I'll give that a try and report back.
