Latest post Fri, Jul 13 2018 10:29 AM by Telegram!. 1 replies.
Page 1 of 1 (2 items)
  • Thu, Jul 12 2018 3:02 PM
    • Marc-Jan
    • Joined on Sat, Oct 18 2008
    • Rotterdam, The Netherlands
    • Posts 2
    • Points 20
    Timewarp from Hell
    Hi there, fellow Avid users.
    Today a Collegue and I where trying to sync some material. The video was running away from the audio, so when the first frame was sync, the last one wasn't. We tried to find the offset by using the Trim-to-Fill effect with the image below as a result. It's a beautiful symmetric image. When you zoom in the Timewarp-window, you can see that the speed varies from 99% to 101% in irregular steps: 2 frames 99%, 3 frames 101%, 1 frame 99% and so on.
    Has anybody seen this before and does anybody know why this is happening?
    Timewarp
    https://imgur.com/6zyOR7k
    Filed under: , ,
  • Fri, Jul 13 2018 10:29 AM In reply to
    Re: Timewarp from Hell
    Is your problem clip using Frameflex?
    From latest release notes, I just noticed this:
    BUG FIXES:
    This release addresses 18 bugs since the last release, including:
    - You could not successfully apply a Trim to Fill Timewarp effect on clips with FrameFlex.
