Latest post Mon, Jul 16 2018 3:13 PM by BarkinMadd. 3 replies.
  • Mon, Jul 16 2018 10:57 AM
    • AntCaladine
    • Joined on Tue, Sep 11 2007
    • Stourbridge, UK
    • Posts 327
    • Points 4,105
    2018.7 poss bug on submaster effect
    Can someone else thats installed 2018.7 do a quick test for me.
    Put two clips into a collapsed layers/submaster effect. Drop an effect on that submaster like flop/resize etc. Then try and remove that effect.
    For me it deletes that entire submaster and contents within it.
    I swear that never happened before.
    EDIT:
    If I ALT drag an effect onto it, I can remove fine.
    Just normal drag/drop effect it deletes.
    So maybe not a bug?
    2x HP Z8 G4, 96GB ram, Win10 Pro 64bit, Nvidia Quadro P4000 8GB AMC 2018.4 1x HP Z820 16GB ram, Win10 Pro 64bit, Nvidia Quadro 4000 AMC 2018.4 2x Aja... [view my complete system specs]
  • Mon, Jul 16 2018 11:28 AM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,571
    • Points 59,725
    Re: 2018.7 poss bug on submaster effect
    Drag and drop (without ALT) will replace the effect, not nest it... I guess when you drop a flop/resize/etc. effect on a submaster effect it replaces the submaster with the dropped effect. Then you you only one effect, not a nested pair.
    Some effects cannot be simply dropped to replace the submaster. For example, if you try to drop a BCC effect (without holding the ALT) MC will warn you that the effect does not apply (BCC cannot perform the role of a submaster).
    It's interesting that I never really noticed this behavior but if, in your example, you step into the 'resize' that you dropped on the submaster, you will notice that the 'resize' has replaced the submaster and that there are only the pair of clips under the 'resize' effect. The submaster is gone.
    Camera(s) PXW-X70, HDR-FX1, Hero 6 Black | MC 18.7 | QT 7.7.9 | BCC 11 | Sapphire 11 | Mocha Pro 5.6 | Titler Pro 6 | Windows 10 Pro x64 | System: P6X58D... [view my complete system specs]
    Steve
    ______________________
    www.nelliedogstudios.com
  • Mon, Jul 16 2018 11:41 AM In reply to
    • AntCaladine
    • Stourbridge, UK
    • Posts 327
    • Points 4,105
    I swear on a submaster I've always just drag/dropped and removed ok.
    On single clips where I stack the effects, then yeah ALT drag and stack em up!
    Most probably doing ALT drag by default without realising, just today drag/drop!
  • Mon, Jul 16 2018 3:13 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,571
    • Points 59,725
    I don't use that workflow very often so it's entirely possible that something changed. I would trust your muscle memory over my tests with this version.
    Steve
