Latest post Tue, Aug 14 2018 2:30 PM by RalphC. 7 replies.
  • Thu, Jul 26 2018 8:25 PM
    • Posts 9,520
    • Points 209,350
    Idea [I] 2018 MacBooks w/10.13.6 not qualified yet.
    Hey everyone....
    The new 2018 Macbook Pro's are out with 10.13.6 and will NOT work with Media Composer 2018.7.1.
    Usually the user will get the following error " 'Exception: std::exception, what: Failed to change priority"
    We are aware and hardware engineering is testing these machine's and once completed, they will be added to the qualified list.
    Until that time, everyone be advised that we don’t support these machines yet.
    AOL IM:  avidmarianna
    Skype: mariannamontague
  • Tue, Jul 31 2018 12:06 AM In reply to
    Re: 2018 MacBooks w/10.13.6 not qualified yet.
    Arrrrghh... I got bit by this on my trash can. Composer works, but it's unhinged my DNxIO.
    Mac Pro (late 2013), 12-core, AMD D700, 64GB RAM, 24TB G-Raid Shuttle Pro XL, Avid Artist DNxIO, Avid Artist Mix, Avid Artist Color, [view my complete system specs]
  • Tue, Jul 31 2018 4:52 PM In reply to
    Michael De Lazzer:
    Different issue.  The issue Marianna speaks of is only related to the 2018 MacBook Pros.  Your issue is likely the BMD driver.  Update to 10.10.1.
    Hope that helps,
    Robert
    MacBook Pro Late 2013 2.6 ghz I7/16gb RAM/GT 750M/1TB PCIe SSD & MacPro Early 2009 24GB/GTX1080Ti/HIT2TB/WD650/WD1TB/ProAvio Scary RAID External. [view my complete system specs]
    Robert A. Ober
    IT Consultant, Vidcaster, & Freelance Preditor(Producer/Editor)
    www.infohou.com
    Houston, TX
  • Tue, Jul 31 2018 4:55 PM In reply to
    I found a slove-- deleted all the MC State and preferences. It reconnected. It was definitely an Avid problem, I had full control of the DNxIO from the OS level.
  • Tue, Aug 7 2018 12:28 AM In reply to
    Hey Michael, Can you tell me where i can find the MC State and preferences? I have this exact problem and need to be editing ASAP but I don't really understand how all the files work and are connected. Would really appreciate if you could walk through what you did to get your's working. Thanks so much!
  • Fri, Aug 10 2018 6:20 PM In reply to
    Applications (folder)>> Avid Media Composer (folder)>> Settings
    Delete:
    MCState and re-launch.
    If that doesn't solve it, then delete everything in the folder and re-launch.
    If that doesn't solve it, then delete everything in the folder again and download and re-install MC.
    That WILL solve it for sure.
  • Sat, Aug 11 2018 8:51 PM In reply to
    Hi Marianna
    Would you have an update on this?
    Johnny
  • Tue, Aug 14 2018 2:30 PM In reply to
    • RalphC
    • Joined on Wed, Sep 2 2015
    • Posts 1,569
    • Points 17,140
    • Avid Customer Advocate
      Avid Customer Service
      Avid Employee
    Hi Johnny,
      New MacBooks and iMac’s: The new 2018 MacBook Pros and iMac’s do NOT currently work with MC 2018.7. Engineering has already made a fix to address this problem in Media Composer 2018.8 and with this version, you can now launch Media Composer on the new 2018 Mac’s. However, this is a “use at own risk” scenario as Avid has just received our 2018 Mac’s and have started qualification testing but not finished yet. Once they have been qualified, you will be notified.
    RalphC
    This is a test. Media Composer 8.8 w/Symphony option, HP Envy 17t-j100 Quad Edition laptop, Windows 10 Pro, Intel Core i7 2.4GHz, 16 GB RAM, nVidia GeForce... [view my complete system specs]
