Latest post Wed, Aug 15 2018 7:32 PM by Marianna. 6 replies.
Page 1 of 1 (7 items)
  • Mon, Aug 6 2018 2:29 AM
    Re-associate Group Clips with Different Bins for "Find Bin"
    Does anyone know if there is a way to re-associate clips with different bins so that when you do a "Find Bin" command, it opens the bin you edited them out of rather than the bin they were originally created in?
    This seems to be happening specifically with group clips. "Find Bin" keeps trying to open the originating bin in the Assistant Editor project rather than the scene bin that I cut the clip in from.
    Thanks, in advance, for your advice!
    Lenovo P710 Windows 10 Pro Dual Xeon E5-2643 v4 3.4GHz (6-core) 64 GB RAM NVIDIA M4000 [view my complete system specs]
  • Mon, Aug 6 2018 5:22 AM In reply to
    Re: Re-associate Group Clips with Different Bins for "Find Bin"
    Damien LeVeck:
    It is really annoying when it crops up. My advice is to post the exact MC error message, and try googling it. Also, reach out on CreativeCow forum and Avid-L2 Yahoo group... perhaps even Reddit where there are veteran MC editors online. If you haven't done so already, set up a support ticket... we all have that option now, thanks to the yearly support concept.. hopefully it is in their database.
    Over the years, I have had the same error you described from time to time.... I think it coincided with renaming a bin that either had GroupClips or some of the sources... but I never figured out the why.
    The only thing I can suggest is to retrace your steps, maybe put the Group Clips back where they originally came from? Maybe it's rebuilding your database... or moving those original bins into a new Folder? Who knows.
    Whatever it is, I hope you find the solution... and can share it. Good luck!
  • Mon, Aug 6 2018 3:10 PM In reply to
    • Posts 10,018
    • Points 215,705
    Damien
    What version of MC are you on now?
  • Mon, Aug 6 2018 4:23 PM In reply to
    2018.7. Projects were created on 2018.2. PC
  • Mon, Aug 6 2018 4:52 PM In reply to
    We narrowed down what is causing this issue. This actually ties into another issue that I've had for a very long time with MC.
    It has to do with subclipping groups or multigroups. I badly wish that when you make a subclip of a group or multigroup, cut the subclip into a squence, then match frame, then find bin, that MC would open the bin that contained the subclip.
    Instead, in the case of a multigroup, MC opens the bin containing subgroup from that piece of the multigroup before the multigroup was created. In the case of a group, MC opens the bin containing the original group before the group was subclipped.
    So, the lesson is, NEVER EVER EVER subclip groups or multigroups.
    BUMP if you wish you could subclip multigroups and have "find bin" open the bin containing the clip that you edited into the sequence!
  • Wed, Aug 15 2018 5:02 PM In reply to
    BUMP.
    This issue persists and is random. Could anyone at Avid weigh in on why this happens?
  • Wed, Aug 15 2018 7:32 PM In reply to
    • Posts 10,018
    • Points 215,705
    Damien
    Michael Philips reorted this to me around the 2018.x and 2018.7 timeframe.  Bug logged and fixed in 2018.8
    Bug Number: MCCET-2532. In some instances, performing a Find did not find all clips and
    sequences, in all bins in the project.
