Latest post Thu, Aug 9 2018 9:55 AM by MikeyB. 4 replies.
  • Wed, Aug 8 2018 2:22 PM
    • JPBU
    • Joined on Sat, Jan 11 2014
    • Canada
    • Posts 135
    • Points 1,830
    Audio scrubbing Always on
    New bug I've been having since the last update. Audio scrubbing is mostly always on, and the cap lock key don't change a thing. Most of the time it's on, but some time for an unknown reason it's off for a few minutes and back on again. Both on the monitor and timeline.
    Any one else having this issue ? Is there an other way than caplock key to turn it off ?
    Media Composer 2018.10 | iMac Pro (2017) 3.2 GHz Intel Xeon W | 64 GB 2666 MHz DDR4 | Radeon Pro Vega 56 8176 MB | G-Raid 16TB Thunderbolt 3 | macOS... [view my complete system specs]
  • Wed, Aug 8 2018 7:10 PM In reply to
    • Posts 10,018
    • Points 215,705
    Re: Audio scrubbing Always on
    JPBU
    Can you update your speifications ???   MC version?  OS?
    I created a case so support can assist
    03526748
  • Wed, Aug 8 2018 7:49 PM In reply to
    • JPBU
    • Canada
    • Posts 135
    • Points 1,830
    I just did. Thanks!
  • Thu, Aug 9 2018 2:13 AM In reply to
    • Martin Fox
    • Joined on Fri, Mar 14 2014
    • Sydney Australia
    • Posts 218
    • Points 2,290
    Yes this has happened to me too.
    there is a good post here about what causes it, but I can’t find it. Something about switching out to other apps, and the coming back to mediacomposer
  • Thu, Aug 9 2018 9:55 AM In reply to
    • MikeyB
    • Edlesborough, UK
    • Posts 469
    • Points 5,810
    I think you're on the right lines. There's a General setting called Enable Caps Lock Protection that's supposed to turn Caps Lock on and off as you switch away to other apps and back to MC, but can get confused. Try switching it (the setting, that is!) off if it's on or vice-versa.
    MacBook Pro 15" 2016 2.7GHz i7 Radeon 455 [view my complete system specs]
