Latest post Tue, May 14 2019 3:14 PM by jef. 2 replies.
  • Thu, Aug 9 2018 4:03 PM
    • M_O
    • Joined on Thu, Jun 4 2015
    • Posts 6
    • Points 85
    "GPU to host transfer failed" message while trying to export
    Hallo everyone,
    I started using the new version (after using 8.6.4 as an academic version) and get this error message while trying to export a same as source file:
    Exception: CACPLGPUOutputconverter::executerequest() GPU to host transfer failed!, hr:0x80000002
    Exporting to QT works.
    I tried the same as source export with two different external hard drives and both attempts failed. I created and worked on the project in the old version and had no problems exporting same as source files.
    Thank you for your help (hopefully...)!
  • Thu, Aug 9 2018 10:42 PM In reply to
    • M_O
    • Posts 6
    • Points 85
    Re: "GPU to host transfer failed" message while trying to export
    Problem solved:
    I disabled the GPU effects in the render settings.
  • Tue, May 14 2019 3:14 PM In reply to
    • jef
    • Joined on Sun, Feb 26 2006
    • Maryland
    • Posts 3,430
    • Points 41,355
    So .....
    I have been having this issue when attempting to make DNx 145 Op1a .mxf files using AMA File Export with 2018.11 on a iMac running OS 10.14.1
    This is a basic workflow I use regularly with no issues.
    The one change that I can isolate is that the source media is linked XDCam HD 50 Mbits.  I normally am using linked ProRes.
    If I consolidate the XDCam I still get the error / failed export.
    If I transcode to DNx 145, all goes smoothly.
    So I think I can say the issue (for me any way) is XDCam HD 50Mbits source.
    Jef
    EDIT: Let me add that turning off GPU render WILL allow this export to succeed.  The time penalty is not huge - maybe 10% slower (?).  But stil ......   On long sequences, this adds up.
    Jef Huey
