Latest post Fri, Mar 8 2019 9:02 AM by Jonno Woodford-Robinson. 9 replies.
Page 1 of 1 (10 items)
  • Mon, Aug 13 2018 11:43 AM
    • CPM
    • Joined on Wed, Apr 24 2013
    • Posts 9
    • Points 105
    Artist Mix stops play on Media Composer v8
    Hi, I have just started at a post outfit using MC 8.9.4
    and I can only get my Artist Mix to work if I press the rec button on the Audio Mixer window.
    On previous versions of MC the mixer would work without arresting play provided the Audio Mixer window was on the Auto panel as opposed to the clip panel.
    Is there anyone who knows if I am doing something wrong?
    to re-cap - play media, touch a fader and play stops unless I play media by selecting rec on the Audio Mixer window.
    Thanks in advance
  • Mon, Aug 13 2018 1:54 PM In reply to
    • Posts 10,176
    • Points 217,615
    Re: Artist Mix stops play on Media Composer v8
    what OS are you on and is the driver the correct one for that OS and MC veraion?
  • Mon, Aug 13 2018 2:33 PM In reply to
    • CPM
    • Posts 9
    • Points 105
    Hi Marianna,
    OS = 10.10.5 Yosemite
    Media Composer 8.9.4
    EuControl = 18.3.0.244
    MC Mix firmware = 1.5.4.0
  • Wed, Aug 15 2018 12:59 PM In reply to
    • CPM
    • Posts 9
    • Points 105
    Please do let me know if there is anyone out there who has a functioning Artist Mix on Media Composer v8
    or is it now obsolete on this version?
  • Fri, Aug 17 2018 6:34 PM In reply to
    • Mike
    • Joined on Thu, Oct 14 2010
    • Lost Angelas, CA
    • Posts 15
    • Points 225
    I've been using my Artist Mix on 8.9.4 for months with no problem.
    (Up until this morning, when it suddenly won't power on anymore. But thats a hardware issue, up until then it worked very well.)
  • Sun, Aug 19 2018 12:36 PM In reply to
    • CPM
    • Posts 9
    • Points 105
    Mike:
    Thanks very much for this Mike - At least I'll be able to investigate my system further to find out what is going on - maybe its an issue with the network connection.
    If I do get to the bottom of it before the end of this project I'll post the outcome.
  • Mon, Oct 22 2018 9:35 AM In reply to
    • CPM
    • Posts 9
    • Points 105
    So - different project, different edit fascility, different mac and the same problem;
    Touch the faders on my control surface and Media Composer stops playing.
    I can mute/solo without the thing stopping but thats it.
    This is PANTS!
    Can I get my control surface back to an earlier firmware? It used to work fine.
    Disappointed with AvidAngry
  • Mon, Oct 22 2018 1:07 PM In reply to
    • Posts 10,176
    • Points 217,615
    Chris
    I have support looking into this - Case # 03576093
  • Thu, Nov 8 2018 9:17 AM In reply to
    • CPM
    • Posts 9
    • Points 105
    Thanks for getting them involved Marianna,
    The upshot is as I expected, this is a problem with MC8.9.4
    After numerous emails back and forth with Avid support I was informed that
    "This specific issue was discovered in Media Composer 8.9.4 and was fixed in 2018.x releases."
    I did suggest that Avid make this issue known, perhaps in the forum so that others don't spend the time I did trying to resolve it but was told that the information is in the release notes for MC2018 Huh?
  • Fri, Mar 8 2019 9:02 AM In reply to
    I'm getting this problem, too.
    macOS Sierra
    MC 2018.10. (so much for fixing the stopping issue in MC2018.x)
    EuControl 3.3.2
    Interestingly, after the Avid stops, usually if I hit play and start moving the faders, it works fine for a bit, but then fader movement, although being followed in the AudioMix tool in the Avid software, there is no audible difference in level. Work-around: open another sequence, then open the sequence I was working on when it stopped functioning and voilà, the audio level has audibly changed to the level that the Artist Mix fader and MixTool are displaying.
    This 'level' issue (not the stopping on playback) has been around since I first purchased the Artist Mix back in 2013.
    Jonno
    iMac (27", Late 2013, 3.5 GHz Intel Core i7, 16 GB, OS X 10.10.5) Connected to 27" Thunderbolt Display, BlackMagic UltraStudio Express (10.7... [view my complete system specs]
    www.fusspotfilms.com
