Latest post Sat, Aug 18 2018 12:30 PM by usatraveler. 2 replies.
  • Thu, Aug 16 2018 11:51 PM
    • h_creation
    • Joined on Thu, Aug 16 2018
    • NJ
    • Posts 6
    • Points 90
    Convert .MTS video files for AMA LINKING
    Hello my issues is with .MTS files. I’m working from a storage cloud and need to convert these high quality .MTS files into low quality file. With the low quality files I want to ama link, and cut a sequence. Next relink to the original .MTS files, and then transcode!
    If I initially ama link to the original .MTS files it plays back choppy and jittery!
    Spec: MacBook Pro 2.6ghz 16gb of ram MC 8.01 [view my complete system specs]
  • Sat, Aug 18 2018 9:46 AM In reply to
    • RobertBe
    • Joined on Fri, Dec 18 2015
    • Posts 6
    • Points 80
    Re: Convert .MTS video files for AMA LINKING
    I'm not sure if you can relink the low quality files back to the mts files in media composer. I would suggest a different workaround:
    1. Ama link all your mts files
    2. in the bin: duplicate the column "name" to "link" (you have to create this Link column first)
    3. duplicate the column "start tc" to "auc tc2"
    4. put all mts files in a new sequence
    5. transcode the sequence to dnxhd36
    That is bulletproof for relinking.
    Relink:
    1. open the bin with the original files and select all
    2. relink the sequence, choose: relink to selected files in open bin
    ,choose "Link"  and Aux tc2"
    Robert
  • Sat, Aug 18 2018 12:30 PM In reply to
    Why not link to the originals, then transcode immediately inside of MC, and edit with the transcodes?  That'll make it easier to relink to the originals at any time.
    Another thing to consider - with MTS files, these are often part of a larger folder structure (a AVCHD folder).  Generally better to link to the FOLDER, rather than directly to individual FILES.  That's because AVCHD splits longer clips across multiple files.  If you link to the folder, MC identifies which clips are spanned, then they show up as single clips in your bin, making for easier clip management.
