Latest post Wed, Aug 22 2018 11:54 PM by Martin Fox. 6 replies.
Page 1 of 1 (7 items)
  • Mon, Aug 20 2018 2:21 PM
    • pianoman72
    • Joined on Thu, Feb 9 2006
    • Dallas, TX
    • Posts 515
    • Points 5,920
    AMA with Canon 5d mkiv footage?
    I'm using 2018.3.0, should I be able to AMA link this footage or do I need to transcode?
    I'm getting the message "can't be linked" in the Source Browser window.
    Clips are good; they play fine in QT and import into Premiere Pro.
    I have the CanonRaw and CanonXF plugins installed.
    Media Composer 8.3.1, OSX 10.9.5 [view my complete system specs]
  • Mon, Aug 20 2018 11:01 PM In reply to
    • Martin Fox
    • Joined on Fri, Mar 14 2014
    • Sydney Australia
    • Posts 217
    • Points 2,285
    Re: AMA with Canon 5d mkiv footage?
    Yes they should link, I’m on the same MC version and I notice the same behaviour “can't be linked “ however I just control click (Mac OS) on the “ can’t be linked and from the contextual menu choose link with QuickTime. They link fine. Multiples can be selected and “linked with-“ in one click.
    you may still need to trancode though as MC needs a lot of cpu to edit with mp4 natively.
  • Tue, Aug 21 2018 2:30 PM In reply to
    • pianoman72
    • Dallas, TX
    • Posts 515
    • Points 5,920
    Perfect, thank you!
    EDIT: Actually that doesn't work for me.  When I sleect 'QuickTime' it retries but returns to "can't be linked.."
    I'm on Sierra and not High Sierra...I wonder if that has anything to do with it.
  • Wed, Aug 22 2018 12:21 AM In reply to
    • Martin Fox
    • Sydney Australia
    • Posts 217
    • Points 2,285
    Are the canon 5d files h264 with a .mov extension?
    i don’t know if Sierra or high Sierra would make a difference, certainly I worked on canon5d footage when I was on Sierra and they linked.
    have you tried the opt drag link process? (Have both an avid bin and a finder window open, click and hold, on a .mov file in the finder then hold down the opt key and drag to an avid bin)
    If you want to share a small file I could try my link process here. - M
  • Wed, Aug 22 2018 3:48 PM In reply to
    • pianoman72
    • Dallas, TX
    • Posts 515
    • Points 5,920
    Thanks for your help.
    Yes, they are h264 with .mov.  I tried the opt drag and nothing happens.
    I've uploaded one of the files and I'll send you the link.
  • Wed, Aug 22 2018 4:08 PM In reply to
    • pianoman72
    • Dallas, TX
    • Posts 515
    • Points 5,920
    I see what it is now.  They guy who put the media on the drive put a "/" in some of the directory names.
    AMA doesn't like that.
  • Wed, Aug 22 2018 11:54 PM In reply to
    • Martin Fox
    • Sydney Australia
    • Posts 217
    • Points 2,285
    great you got it sorted!
