Latest post Wed, Sep 12 2018 8:15 PM by pierreh. 5 replies.
Page 1 of 1 (6 items)
  • Wed, Sep 5 2018 7:25 PM
    • aynsb
    • Joined on Thu, Oct 20 2011
    • Posts 37
    • Points 395
    lag on client monitor
    Hey there,
    I'm running MC 2018.8.0 on a 3.5 GHz Core Intel Xeon E5 Mac Pro (late 2013) with an Avid Mojo DX (2018.8 driver installed), and I've got a lag on my client monitor of a few frames as compared to playback on my desktop monitor + audio monitors.  In other NLE's, I've seen settings to offset such a lag, but can't find anything of the sort in Media Composer.  Hoping it actually does exist somewhere?
    Aynsley
  • Wed, Sep 12 2018 9:16 AM In reply to
    • derDoyle
    • Joined on Tue, Aug 18 2015
    • Berlin, Germany
    • Posts 74
    • Points 860
    Re: lag on client monitor
    You can fix this with a console command "moncondel #"
    #=number of frames.
    Doyle
    Clients: MacPro6.1 (2013 "Trashcan"), 3,5GHz 6-Core, 16GB (1866) RAM, AMD FirePro D500, 256GB SSD, macOS 10.12.2, Avid MediaComposer 8.7.2, NitrisDX... [view my complete system specs]
    Passionate In-House Avid Support
    Admin of the German Avid Community on Facebook
  • Wed, Sep 12 2018 10:28 AM In reply to
    • pierreh
    • Paris, London
    • Posts 1,205
    • Points 14,565
    Nice one!
    Had the same problem in the new place where I'm freelancing. Turned out that it was the Sony TV adding a delay to the video (3 frames). Ended up monitoring the sound thru the TV (instead of directly out of the Mojo) and I'm now in sync. At least on the big monitor...
  • Wed, Sep 12 2018 10:38 AM In reply to
    • derDoyle
    • Berlin, Germany
    • Posts 74
    • Points 860
    We have the same setup, MojoDX with Client monitor and a big Sony TV.
    Client Monitor has a delay of 2 frames and the big Sony up to 4.
    So we have two choices, watch with client monitor in sync or with the big TV (sound through the TV) in sync.
  • Wed, Sep 12 2018 2:32 PM In reply to
    • Ryan Johnson
    • Joined on Tue, Dec 12 2006
    • New York, NY
    • Posts 28
    • Points 370
    moncondel works, but it's not persistent. You need to set the value each time you launch Media Composer.
    As of MC 8-ish (I forget which release), you can now adjust this offset using the "Desktop Play Delay" setting.
    There's two values in there:
    "Desktop/Hardware Sync Delay Frames"
    This will shift the position of the audio relative to BOTH your external video monitor and the computer display.
    "Video Sync Delay for Remote Client Milliseconds"
    This will offset both the video and audio coming from your hardware relative to your computer display. At 24 FPS, one frame is about 42 ms.
    "Desktop Play Delay" is listed as a 'Site' setting, so it's local to the machine, and doesn't travel with the project or user.
    I should note that we've been using this setting with AJA and Blackmagic hardware exclusively. I haven't tried it with Avid's own hardware.
    -rj
    MacPro's, OSX 10.11.6, MC 8.8.2, Isis 5000 [view my complete system specs]
  • Wed, Sep 12 2018 8:15 PM In reply to
    • pierreh
    • Paris, London
    • Posts 1,205
    • Points 14,565
    Desktop play delay only allows you to delay the display. You can't have it earlier so it wouldn't have been of any help unfortunately.
