Latest post Fri, Nov 2 2018 4:11 PM by ramz434. 27 replies.
Page 2 of 2 (28 items) < Previous 1 2
  • Sat, Sep 8 2018 11:46 AM In reply to
    • Martin Fox
    • Joined on Fri, Mar 14 2014
    • Sydney Australia
    • Posts 220
    • Points 2,330
    Re: XAVC-S Timecode - AMA link
    DIESELE:
    Just source browser linked to A7Sii XAVC-S footage without any timecode issues guys - MC2018.8
    Its detecting the right codec right - no mention of XAVC-S?
    All seems to work well here without the previous need for 3d party processing?
    Footage is noisier than I expected for one of the best low light cameras - ISO 20,000 - any tips for reducing it in Avid?
    Cheers
    D
    what plug-in are you using?
  • Sat, Sep 8 2018 12:19 PM In reply to
    • scocklin
    • Maryland
    • Posts 652
    • Points 7,840
    Upgraded to 2018.8 and seeing correct timecode in UHD format but not 1080,  below is an image from Resolve showing correct timecode in 1080 Format.
    Files where created on a Sony A7RII camera with timecode set to time of day free run.
    HP Z800 2x 3.46GHz Hex Core X5690, 48GB Ram, Windows 10, Samsung SSD 850 Pro 512GB, Avid Mojo DX, Nvidia Quadro K4000, GTX 1080 FTW, DeckLink SDI 4K,... [view my complete system specs]
  • Sat, Sep 8 2018 4:48 PM In reply to
    • ramz434
    • Long Island
    • Posts 193
    • Points 2,410
    This is the problem that I had - UHD footage had correct TC - the HD footage was actually a mixed bag. Some of it AMA'd with the correct TC, but some of it didnt.
    - HP Z400/24gb ram/Windows 10/MC8.9.4/256gb Samsung SSD/ NVidia GTX 1080/HP ZR22 Monitors/ - Macbook Pro/16gb ram/OS 10.13/MC8.9.4/NVIDIA GeForce... [view my complete system specs]
  • Sat, Sep 8 2018 4:55 PM In reply to
    • ramz434
    • Long Island
    • Posts 193
    • Points 2,410
    DIESELE's footage was shot at 100 fps and the TC came in fine at HD 1080 (Im assuming thats a 25fps project).  scocklin's footage was 24 and the TC didnt link correctly (not sure of project fps - assuming 24) . Im going to check what the frame rate was for the footage Im having trouble with. It was a mixed rate shoot (some 60, some 24) - and only some of it came in incorrectly. My project is set at 24 fps.
  • Sat, Sep 8 2018 5:09 PM In reply to
    • DIESELE
    • Joined on Mon, Apr 28 2008
    • Cymru/Wales
    • Posts 1,066
    • Points 13,150
    Yeah Im 25P - everything must multiply with 25 for an easy jerk free life :).
    Scocklin was 23.976 I think.
    Happy to swap files and do any tests if it helps you guys.
    Symphony 2018.11, Blackmagic Intensity Pro (cant get it working well in 4k though for client monitor - which was the point...), WIN 10 on 2000Mbps M.2 SSD, Nvidia Quadro K2000, Asus X99 Mobo, 4.0 GHz Hex core CPU, 32Gb 2800 Mhz RAM, WD Black 8Tb RAID10
    VIDEO MEDIA PRODUCTION COMPANY AND FACILITIES CARDIFF, LONDON, BRISTOL, WALES, CRACKING PRODUCTIONS
  • Sat, Sep 8 2018 6:04 PM In reply to
    • scocklin
    • Maryland
    • Posts 652
    • Points 7,840
    DIESELE:
    I was hoping that you where right but I changed frame rate to  29.97, linked to an Avid 29.97 project and got the same results.
    I then created a 25p file from my A7RII camera, changing from NTSC to PAL and the correct time code show up in an Avid 25p project. So PAL seems to work fine but NTSC HD 1080 does not.
    If this is a camera problem, why does the correct 1080 NTSC time code play in Sony Catalyst, Resolve and Convert 3?
  • Sat, Sep 8 2018 6:13 PM In reply to
    • DIESELE
    • Cymru/Wales
    • Posts 1,066
    • Points 13,150
    Go PAL mate - change countries - may be easier?  Computers love even numbers rather than odd multiples ;)  Sorry I jest :)  If you want files to test and dismiss let me know - maybe even test 25P on your generated files?  I know nothing about Drop Frame / NDF but is that a setting?
  • Sat, Sep 8 2018 6:27 PM In reply to
    • scocklin
    • Maryland
    • Posts 652
    • Points 7,840
    DIESELE:
    It looks like we may have a software problem (bug) in NTSC land.
    When I lived and worked overseas back in the 80s shooting NTSC you British where always telling me that PAL is superior to NTSC (Never The Same Color Twice)  Big Smile
  • Sun, Sep 9 2018 10:23 AM In reply to
    • DIESELE
    • Cymru/Wales
    • Posts 1,066
    • Points 13,150
    LOL 'Never Twice The Same Colour' - proper geek engineers' gag ;) More lines or less flicker ? Tough call ;)  Hope you get it sorted mate.
  • Mon, Sep 10 2018 3:18 PM In reply to
    • Posts 10,089
    • Points 216,625
    Kris, Martin, Devon, and Steve
    Dave escalated this and I created a case # 03547843.  Kris you are the primary but the rest of you have been added so when support reaches out, you will all be notified and feel free to jump in if you have anything to add.  I attached all the images to the case so they have those...
    Thanks Dave Stone!
  • Mon, Sep 10 2018 5:17 PM In reply to
    • scocklin
    • Maryland
    • Posts 652
    • Points 7,840
    Thank you, Dave and Marianna!
  • Mon, Sep 10 2018 11:39 PM In reply to
    • Martin Fox
    • Sydney Australia
    • Posts 220
    • Points 2,330
    Thanks for looking into this, I’ve seen posts on colour grading sites with people scratching their heads!
  • Fri, Nov 2 2018 4:11 PM In reply to
    • ramz434
    • Long Island
    • Posts 193
    • Points 2,410
    Has there been any update on this? I've just installed 2018.10 and am having the same problem with TC being read using XACV-S clips. Clip 0001 will have the correct TC, but Clip 0002 starts again at 00:00:00:00.
    This last shoot I got this morning has 147 of 180 clips without proper TC. All of the clips were shot 59.94. There is no technical difference between the shots that do have correct TC and those that dont
