Latest post Tue, Oct 2 2018 3:45 AM by Alayne Holmes. 32 replies.
Page 2 of 3 (33 items) < Previous 1 2 3 Next >
  • Mon, Sep 10 2018 1:23 PM In reply to
    • Pixel Monkey
    • Posts 1,233
    • Points 15,560
    Re: eliminate interlace
    Hmmm... Try again. The images are not coming through. Perhaps make them a different file type? Like a JPEG?
    ACA Leader__Avid Pro Vid Moderator__Specs? Many. All qualified. But I still do stupid things. :) [view my complete system specs]
    Chris Bove' (Pixel Monkey)
    Twitter: Follow @heybove
    Blog for Craft Editors
  • Mon, Sep 10 2018 1:38 PM In reply to
    • speran
    • Joined on Thu, Jan 7 2016
    • Posts 37
    • Points 485
    is there any other way that I could send screenshots? cause I can't attach them in here
    Pixel Monkey:
  • Mon, Sep 10 2018 1:45 PM In reply to
    • Pixel Monkey
    • Posts 1,233
    • Points 15,560
    Sure. Email me directly. alwaysediting@yahoo.com.
  • Mon, Sep 10 2018 2:56 PM In reply to
    • Pixel Monkey
    • Posts 1,233
    • Points 15,560
    Hi all. Attached here are screen grabs Sonia sent me (uploaded with her permission).
    These seem like standard SD "stair-stepping", and not artifacts. Probably caused by simply viewing low-res SD footage that is being up-sized to fit the HD raster. Agreed?
    • Pixel Monkey
    • Posts 1,233
    • Points 15,560
    And the other...
  • Mon, Sep 10 2018 3:27 PM In reply to
    • speran
    • Posts 37
    • Points 485
    isn't it caused by interlacing issue? because I view the time line in high res. the problem is the lines on the fabric roll the guy is carrying and other straight lines specially white lines all over the 4.3 images.
    Pixel Monkey:
  • Mon, Sep 10 2018 4:09 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,527
    • Points 45,365
    speran:
    Agreed. If it were interlace issues, then you'd see alternating scan lines in the gentleman holding the rug. Speran, here's an example of an interlaced image:
    (public domain image)
    Notice the combing effect of the alternate scan lines. You may see this on even relatively slow moving objects (this example's rather extreme for emphasis).
    (BTW, I posted a short tutorial, with images, on how to post images in the Getting Started forum, pinned to the top).
    Dave S.
  • Mon, Sep 10 2018 4:40 PM In reply to
    • speran
    • Posts 37
    • Points 485
    how can I see it in high resolution? by the way I have the same issue as you show in the picture as well.
    DStone:
    speran:
  • Mon, Sep 10 2018 7:17 PM In reply to
    • Pixel Monkey
    • Posts 1,233
    • Points 15,560
    Sorry, there is no way to see it in a higher resolution than it is. If the image was captured by a camera shooting 720 pixels wide by 486 pixels high, then that's all you get. Those artifacts you are seeing are the actual interlaced pixels. They only become smoother when played. Stretching an SD image larger, over a 1920x1080 pixel canvas doesn't increase then number of pixels in the SD image. It simply makes the pixels larger.
  • Mon, Sep 10 2018 8:25 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,527
    • Points 45,365
    To be honest, there's no really good way of getting rid of interlace. The best method is where the effect analyzes the even and odd lines, and then shifts left and right 1/2 the distance to bring the two into alignment. But even this isn't perfect if the motion varies over the course of 1 frame. And it requires analyzing every single frame as the motion may vary from frame to frame.
    MC does something like this (and it may be that this is what it really does) when you use Adaptive Deinterlace Source on a timewarp. But it's time and resource intensive. However the results are generally pretty good. As to why you couldn't use it (as mentioned in your earlier post), here's the procedure in case you missed a step:
    Promote the motion adapter on the clip in the sequence to a timewarp. Set it to Both Fields, input source Interlaced, output Progressive, and check the Adapter Deinterlace Source option. If you can't change it, right-click on the master clip in the bin and choose Get Info. Look at the Field Motion setting. It should say Interlaced.
    Dave S.
  • Tue, Sep 11 2018 8:20 AM In reply to
    • speran
    • Posts 37
    • Points 485
    thank you for your response. you mentioned that I should Promote the motion adapter on the clip in the sequence to a timewarp. Set it to Both Fields, input source Interlaced, output Progressive, and check the Adapter Deinterlace Source option.  could you please write me the steps on how to do that. Because when I do it it won't work. I'm thinking that I do something wrong. I always get the window filter does not apply.
    DStone:
  • Tue, Sep 11 2018 2:49 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,527
    • Points 45,365
    What are the results from Get Info on the clip in question? Also are there any other filters on that clip?
    Dave S.
  • Thu, Sep 13 2018 2:38 AM In reply to
    • jef
    • Joined on Sun, Feb 26 2006
    • Maryland
    • Posts 3,347
    • Points 40,455
    speran:
    I imagine you are getting this error because the source clip is an interlace clip in a progressive project.
    Select the clip, click on the motion effect edit button (left side of the timeline), then click on the Promote button in the top of the motion effect edit window.  You should now be able to follow the suggestions give.
    Good luck,
    Jef
    Jef Huey
  • Mon, Oct 1 2018 1:27 PM In reply to
    • speran
    • Posts 37
    • Points 485
    Hi everyone,
    I was able to use the timewrao effect to deinterlace my footages but after I render the effect and I replay the clip the image stutters. is there a reason for that? how can I fix the problem?
    thanks,
    Sonia
  • Tue, Oct 2 2018 2:11 AM In reply to
    • Martin Fox
    • Joined on Fri, Mar 14 2014
    • Sydney Australia
    • Posts 220
    • Points 2,330
    Do you mean the motion does a dance of going forward and then a bit backward?
    I am workung on a doc that has alot of mini dv footage that is interlaced.
    The footage has the lower field first (that means the first bit of motion is captured in the second"lower field" and the next slice of time is captured in the first field, which is different to most other video codecs
    Ive been scaling it up to HD re-encoding as DNX and de-interlacing in iFFmpeg before AMA linking in the avid.
    here is an example of the original and the de-interlaced and the de-interlaced filter setting in iFFmpeg
