Latest post Mon, Sep 10 2018 11:55 PM by Martin Fox. 1 replies.
Page 1 of 1 (2 items)
  • Sat, Sep 8 2018 4:39 PM
    • att
    • Joined on Sat, Sep 8 2018
    • Posts 11
    • Points 165
    importing as 36 mxf
    Can I import videomaterial as 36 MXF and then export it to grading and sound?
    And when I get the graded material then I just create a new 175x MXF project
    and import the graded material as 175x MXF (eller another good format?
    Thank you!
  • Mon, Sep 10 2018 11:55 PM In reply to
    • Martin Fox
    • Joined on Fri, Mar 14 2014
    • Sydney Australia
    • Posts 223
    • Points 2,365
    Re: importing as 36 mxf
    You can export 36 Video to grading but that is a very low resolution and not a good workflow imo.
    the usual workflow for this;
    link the footage using the source browser
    trancode linked footage to editing resolution dnx36 is lowest Rez and does not consume as much hard drive space as higher rez
    edit
    relink the finished edit to the original linked files
    transcode the relinked sequence to dnx 175 (or higher)
    export for colour grading
    check out this workflow utube from avid
    im finding the link https://youtu.be/PKaK397eVLI
