Latest post Wed, Sep 12 2018 8:43 AM by Bruno M. 7 replies.
  • Mon, Sep 10 2018 1:12 AM
    • brett
    • Joined on Wed, Nov 17 2010
    • tampa
    • Posts 49
    • Points 675
    bizzaro world error
    Anyone seen this?  I haven't changed a thing in years..imported this new sequence that's been synced up (same process since 2014).  error message pops up and I can't play or do anything.  I've opened the master in other projects same error message.
    7820x 32GB ram GTX 1070 m.2 a7sII Magic bullet looks > resolve. yep [view my complete system specs]
    www.hatfieldproductions.com
    Filed under: ,
  • Mon, Sep 10 2018 1:13 AM In reply to
    • brett
    • tampa
    • Posts 49
    • Points 675
    Re: bizzaro world error
  • Mon, Sep 10 2018 11:50 AM In reply to
    • Bruno M
    • Joined on Thu, Feb 11 2010
    • London, UK
    • Posts 560
    • Points 7,130
    brett:
    You're going to have to give a few more details, such as....
    What do you mean by imported... an AAF import or just opening a previously created MC sequence?
    What version of MC... is this the same version that was used to create the sequence?
    What media are you using?
    What sort of error message are you getting?
    HP Z800, HP G3 Studio, SonnetFusion RAID, Mojo DX, Symphony 2018.9, JVC DTV1910 HD tube monitor, HP Dreamcolor, Avid Artist Color [view my complete system specs]
  • Mon, Sep 10 2018 12:53 PM In reply to
    • Posts 10,156
    • Points 217,345
    Along with what Bruno suggests - I dont see an image attached.  Can you email me the information and the error?
  • Mon, Sep 10 2018 8:50 PM In reply to
    • brett
    • tampa
    • Posts 49
    • Points 675
    picture wont upload..just says duplicate post... i ended up re doing the project and build...it was on a few clips for some reason...so i deleted the ama linked ones when they were transcoded, and replaced them with the transcode and the errors went away...id love to know what in the world was going on.
  • Wed, Sep 12 2018 2:23 AM In reply to
    • brett
    • tampa
    • Posts 49
    • Points 675
  • Wed, Sep 12 2018 2:27 AM In reply to
    • brett
    • tampa
    • Posts 49
    • Points 675
    Error is back again.
    ama link -> Exported to pluraleyes to sync up tracks.
    once put back into avid I get the error message... if I substitute over the original clips that were AMA with a new transcode clips the errors finally go away..I've never seen the error code before and have never had to go through each error after putting in each new transcoded clips.
    I am on the newest avid currently. Ill attach a pic of the error code...weird stuff going on.
  • Wed, Sep 12 2018 8:43 AM In reply to
    • Bruno M
    • London, UK
    • Posts 560
    • Points 7,130
    So it's the file from Pluraleyes that's causing the problem. I'm assuming you're using Pluraleyes version 3.5 (or earlier) since they stopped supporting Avid from version 4
    brett:
    Do you mean you've not had this problem before on the current version of MC, or with earlier versions? You said in your original post that you hadn't changed a thing in years, yet you say you're on the latest version of MC, which hasn't been around for years.
    Just wondering why you're using the Pluraleyes software to sync up your clips since MC has had waveform analysis for a while now.
