Latest post Fri, Sep 14 2018 4:19 PM by Fish. 4 replies.
  • Thu, Sep 13 2018 6:54 PM
    • Fish
    • Joined on Sat, Oct 15 2005
    • Filet Post, Halifax NS
    • Posts 530
    • Points 6,435
    ALL VERTICAL WORKFLOW - IMPORT, EDIT, EXPORT
    I have vertical video (NOT cropped 16x9 footage). Need to edit it vertically, and export it vertically. Should be simple given I can plug in whatever numbers I want into the Source settings. But every attempt to apply a transformation in the source setting results in a cropped output. The source settings window is assuming my footage isn’t what my footage is. My source setting window doesn’t believe me. Crazy that the rotate function insists on cropping it and doesn’t simply rotate the whole frame in the composer window. I’ve scoured the tutorials available and nothing is a good fit. It seem impossible that I can’t find a solution to this. Even Kevin’s tutorial assumes you’d be shooting 16x9 and cropping. NO! Don’t want to do that. Footage is 9x16. Is this possible to simply apply a source setting? Sad if it isn’t.
    2012 Westmere MacPro 2 x 2.66 GHz 6-Core Intel Xeon) 6 GB 1333 MHz DDR3 ECC ATI Radeon HD 5870 1024 MB As of Jan 2015 - OS X 10.9.5 (13F34) [view my complete system specs]
    AVID man, AVID fan (since 1993 with version 4.5 - before multiple tracks!)...like to solve my own problems and I try not to bother anyone unless I'm really stumped.
  • Thu, Sep 13 2018 8:50 PM In reply to
    • Mark Renz
    • Joined on Tue, Feb 21 2006
    • Kansas City, MO
    • Posts 1,039
    • Points 12,920
    Re: ALL VERTICAL WORKFLOW - IMPORT, EDIT, EXPORT
    Did you happen to try to create a custom project with the size needed to see if that makes a difference?
    Media Composer Nitris DX 2018.8 with Symphony option Win10 64Gb Ram * Media Composer 8.8 with Symphony option Nitris DX Dual 2.66GHz "Westmere"... [view my complete system specs]
  • Fri, Sep 14 2018 12:44 PM In reply to
    • Fish
    • Posts 530
    • Points 6,435
    Sorry...should ahave mentioned, it IS a custome project size.
    And the composer windows are vertical (so, good.)
    The only road block is interpreting the footage.
  • Fri, Sep 14 2018 1:45 PM In reply to
    I got mine working.
    My test was to make a 1080x1920 project
    AMA link a 1920X1080 video.
    The trick was changing the Frame aspect ration in the lower frameflex box to 9:16 then stretching out the frameflex frame in the RH preview. Worked fine.
  • Fri, Sep 14 2018 4:19 PM In reply to
    • Fish
    • Posts 530
    • Points 6,435
    RH preview?  I've changed the ratio. But the stretching part does not work it won't let me change the ratio of the box it applies. only smaller or larger.
    It really should be simpler than this.
