Latest post Sat, Sep 15 2018 11:56 PM by Martin Fox. 1 replies.
Page 1 of 1 (2 items)
  • Sat, Sep 15 2018 11:52 AM
    • dkfilm89
    • Joined on Sun, Sep 9 2018
    • Posts 3
    • Points 35
    Shift Clips around
    Hello again,
    Ive another issue moving a group of clips around to a different section of the timeline.Maybe you got a fast and esay soultion for me?As you can see here I selected those clips with "shift" (they got interview original sound, which as to me be audio-track 1)
    When I move them to the beging of my timeline, the following thing happens:
    The atmo-audio on track A3 stays there and doesnt move with the other clips... synch-locks are turned on, the audio is part of the video-file. Does the extract/splice tool only work on the video/audio tracks selected?
    Are there other ways to do this action, to move this group of clips in front of the other one? Thank you!
  • Sat, Sep 15 2018 11:56 PM In reply to
    • Martin Fox
    • Joined on Fri, Mar 14 2014
    • Sydney Australia
    • Posts 222
    • Points 2,360
    Re: Shift Clips around
    You can also select track 3 (using false edit to define the boundaries), but this is more work. I would option extract the tracks and insert them in the new position. The option key loads the extracted clips into the source side.
    so the workflow would be
    mark an in at the start of the section to be moved
    mark an out at the end
    turn on the track lights for your selection
    keyboard input would be opt X to extract
    place your playhead at the new insert point
    insert
