Latest post Sat, Sep 22 2018 12:53 PM by Ulrich Thomsen. 2 replies.
  • Fri, Sep 21 2018 10:08 PM
    Trim to A or B Side shortcut key selects random trim modes
    Hey
    Hitting the shortcut key on my AVID Logickeyboard selects trim A, or B side, but sometimes it turns red, Ovewrwrite Trim and sometimes Yellow Ripple trim. Why is that?
    Avid tells me it's supposed to default to yellow, ripple trim.
    Best Ulrich
    Media Composer 2018.12.1 Mac Pro, late 2013, 2.7 GHZ 12 Core Intel Xeon E5 64 GB 1867 Mhz DDR3 memory AMD FirePro D700 6144 MB [view my complete system specs]
  • Sat, Sep 22 2018 10:27 AM In reply to
    • Martin Fox
    • Joined on Fri, Mar 14 2014
    • Sydney Australia
    • Posts 220
    • Points 2,330
    Re: Trim to A or B Side shortcut key selects random trim modes
    I think you are using the smart trim tool, if your mouse cursor is nearer the top of the clip in the timeline, you are able to use the overwrite (red)trim tool
    if you mouse is nearer the bottom of the clip the smart tool turns yellow and is a ripple trim tool.
    I don’t use the smart trim tools, I’m going from memory, I’ll check next time I’m on the system.
    Smart tools are activated or deactivated on the left side of the track lights in the timeline.
  • Sat, Sep 22 2018 12:53 PM In reply to
    you think correctly. I am using the smart tools... that's all on purpose. All tools selected. That's not the issue...
    the issues is that when I press the keyboard shotcut key. Trim A or B side (doesn't matter) The trim mode should default to YELLOW, Ripple Trim, which is what I want. BUT sometimes, and quite often, it starts RED, the overwrite Trim. Whay is that?
    Sure i can turn off RED overwrite trim, but that kind of defeats the purpose of having the smart tools turned on.
