Latest post Wed, Oct 3 2018 9:23 AM by speran. 9 replies.
Page 1 of 1 (10 items)
  • Mon, Oct 1 2018 8:13 PM
    • speran
    • Joined on Thu, Jan 7 2016
    • Posts 37
    • Points 485
    Stuttering image after render
    Hi everyone,
    I came across an issue while adding effect to my timeline. after rendering any effect the image stutter while playback. I work with Macbook pro high Sierra 10.13.6 and have the latest version of avid media composer. is there a render setting that is problematic and causes stuttering? I also see red coloured lines in timeline after rendering.
    I appreciate your help
  • Mon, Oct 1 2018 8:27 PM In reply to
    • jef
    • Joined on Sun, Feb 26 2006
    • Maryland
    • Posts 3,373
    • Points 40,745
    Re: Stuttering image after render
    After you playback and see the stuttering, are there any colored stripes in the timeline?  Thin yellow and / or red lines under the video layers?
    If so, this is Avid telling you it is having trouble playing back the render.  Check the doc for more info as to what they mean in detail.
    Jef
    Jef Huey
  • Tue, Oct 2 2018 2:52 PM In reply to
    • speran
    • Posts 37
    • Points 485
    Hi Jef,
    yes I have thin red lines under the video layers.
    jef:
    Jef
  • Tue, Oct 2 2018 3:00 PM In reply to
    What resolution did you render at? check your media creation settings
  • Tue, Oct 2 2018 3:20 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,545
    • Points 45,590
    Also check to see what disk you're rendering to.
    Dave S.
  • Tue, Oct 2 2018 4:27 PM In reply to
    • jef
    • Maryland
    • Posts 3,373
    • Points 40,745
    speran:
    Hi Jef,
    jef:
    Jef
    Look here for more info:http://avid.force.com/pkb/articles/en_US/troubleshooting/en274819
    I am going to guess you have your renders set to a drive that is not fast enough or your renders are set to a codec that is not appropriate.
    Jef
    Jef Huey
  • Wed, Oct 3 2018 9:14 AM In reply to
    • speran
    • Posts 37
    • Points 485
    DNxHD 185 x
    Pat Horridge:
  • Wed, Oct 3 2018 9:15 AM In reply to
    • speran
    • Posts 37
    • Points 485
    to the same disk as the media files
    DStone:
  • Wed, Oct 3 2018 9:16 AM In reply to
    You need a reasonably fast drive for reliable DNx185x playback and a fast ennection USB3 or thunderbolt or direct SATA.
    WHat is you media drive (and confirm the media is being rendered to that drive) and hows it connected.
  • Wed, Oct 3 2018 9:23 AM In reply to
    • speran
    • Posts 37
    • Points 485
    I use Seagate BUP BK Media. a normal harddrive with USB 3
    Pat Horridge:
